Old 08-02-2012, 07:33 AM   #21
Herk7769's Avatar
Originally Posted by boubou View Post
Wish the RV places were totally and completely reliable and trustworthy
One stop shop and drive out with camper knowing it's safe
"If wishes were fishes..."
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 08-02-2012, 07:34 AM   #22
Brigitte
boubou's Avatar
Tpms doesn't register new pressure. Says 46 when I put in 55
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 08-02-2012, 07:37 AM   #23
Herk7769's Avatar
They need to be reprogrammed for the new "full" pressure.
Check the manual to see how that is done.
Old 08-02-2012, 07:50 AM   #24
Don't understand. My TST registers whatever is in the tire, the alarm limits should be reset to the desired max & min.
Old 08-02-2012, 08:00 AM   #25
"Don't understand. My TST registers whatever is in the tire"
I believe the OP is talking about his truck's factory monitor. The factory probably didn't consider anyone putting such heavy-duty tires on a half-ton!
bakken is offline   Reply With Quote
Old 08-02-2012, 08:01 AM   #26
Herk7769's Avatar
There are many different models of tire sensors. The crappy ones I got with my camper (for a now i know outrageous sum) need to be reprogrammed as they came factory set to 25 psi alarm. They do not display anything unless they are in alarm. By 25 PSI you are dead meat.
Old 08-02-2012, 08:05 AM   #27
Mickeetwo's Avatar
Smile
Light Truck Tires
Since light truck tires are often available in multiple load ranges, the appropriate load range is identified immediately following the size's rim diameter in Tire Rack's descriptions.
LT-Metric, LT-Flotation and LT-Numeric tires are branded with their load range (Load Range E or LRE) or their ply rating (10 Ply Rated) on their sidewalls and list their appropriate load range letter in their descriptions as LT245/75R-16 E, 7.50R-15 D or 31x10.50R-15 C.
LT-Metric, LT-Flotation and LT-Numeric Light Truck Tires
Load Range Ply Rating Max Load Pressure
B 4 35psi
C 6 50psi
D 8 65psi
E 10 80psi
F 12 95psi
Trailer tires a similiar but start with ST.....Example ST205/75R15 LRD
LRD meaning Load Range D
2006 Flagstaff 831RLSS
2008 Tahoe LTZ
1999 Siverado
Mickeetwo is offline   Reply With Quote
Old 08-02-2012, 08:07 AM   #28
Didn't realize they had those kinds of monitors. Can you set a high limit & temperature?
Old 08-02-2012, 08:11 AM   #29
Herk7769's Avatar
Like I said; another dealer rip off.
Old 08-02-2012, 08:22 AM   #30
Brigitte
boubou's Avatar
Hey! On the road now and TPMS decided
To show correct pressure /)
Superglide 2700
Timbrens
Old 08-02-2012, 08:24 AM   #31
Herk7769's Avatar
Are you texting and driving!!!!!!
Eyes on the road; hands on the wheel!
Old 08-02-2012, 08:29 AM   #32
Herk7769's Avatar
B 4 35psi
C 6 50psi
D 8 65psi
E 10 80psi
F 12 95psi
Load range and plies are not accurate anymore. The number of plies depends on the material used to construct the ply. New materials allow manufacturers to keep the load range with less plies.
Old 08-02-2012, 08:42 AM   #33
Mickeetwo's Avatar
I have to respectfully disagree with you on this one. The load range is still the same as posted by the manufacturer and those numbers are current.
Today's load range/ply ratings do not count the actual number of body ply layers used to make up the tire's internal structure, but indicate an equivalent strength compared to early bias ply tires. Most radial passenger tires have one or two body plies, and light truck tires, even those with heavy-duty ratings (10-, 12- or 14-ply rated), actually have only two or three fabric plies, or one steel body ply.
2008 Tahoe LTZ
1999 Siverado
Old 08-02-2012, 09:08 AM   #34
Brigitte
boubou's Avatar
Hahahah! No way! I am the Co-Pilot
Superglide 2700
Timbrens
Old 08-02-2012, 11:19 AM   #35
Herk7769's Avatar
Oops. What I meant to say; but it came out wrong; is that plies and load range are not implicit.
For example your list implied that a load range D tire has 8 plies.
No question that a load range D tire will handle 56PSI.
Old 08-05-2012, 11:20 PM   #36
Just a member
kandl's Avatar
That is a very good question. The rims should be stamped with their maximum PSI.
Had the wheels off today. Detailed inspection revealed nothing that would indicate a max tire pressure. Lot's of manufacturer data, "made in China" and a cute little pentastar (but of course), but no inflation data. The wheels are OE upgrades and come equipped with direct TPMS and aluminum valve stem. Safe max pressure? Again, good question and likely a crap shoot without a peek into the original engineering.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
