Originally Posted by boubou
You know, I go to garages and RV places to get everything done right and it seems as if no one has a clue as to what is what.
I am NOT an engineer or a mechanic. I am a dental hygienist and I know my job. I find all of this overwhelming and it looks like I cannot even trust the professionals (mechanics and RV techs) do know their own job.
Just about to leave for a trip and trying to decide tire pressure now. Of course, it's rubber stem valves. Why would the Dodge garage even bother changing them to steel when they didnt have a clue about what pressure I should put in them for towing? All they told me was 35 psi
What a joke!
Anyways. Should I put 50, 55 or 60?
Sorry about the rant
Brigitte
I believe you would still be safe with 55 PSI. That should keep the tires inflated and retained on the rim shoulder should you hit something on the highway; yet stay below the max rating on your stems.
You should also take the time once you are loaded to get a good weight check for the truck and camper. Many good threads here on how to do that.
Just remember you will need 2 weighs with a travel trailer and 3 weighs if you use a travel trailer with a Weight Distributing Hitch.
5th Wheel (2 weighs):
1) Truck (alone with all people, hitch, full gas, and gear aboard) - Front axle; Rear axle weights (add together for total weight)
2) Hitched (truck exactly as above plus connected camper) - Front axle; Rear Axle; Camper axles
(add all 3 together for combined weight)
(add front and rear together for loaded truck weight)
(subtract "alone" truck weight form "hitched" truck weight for pin weight)
(Add pin weight to camper axle weigh(s) for total camper weight)
Travel Trailer (3 weighs):
2) Hitched (truck exactly as above plus connected camper WITHOUT WD bars connected) - Front axle; Rear Axle; Camper axles
(subtract "alone" truck weight form "hitched" truck weight for true tongue weight)
(Add true tongue weight to camper axle weigh(s) for total camper weight)
3) 2) Hitched (truck exactly as above plus connected camper WITH WD bars connected) - Front axle; Rear Axle; Camper axles
(Compare "distributed axle loads" to max axle ratings to be sure front or camper axles have not been overloaded by using the WD links/settings you chose)
