Old 07-31-2012, 09:17 PM   #1
Brigitte
boubou's Avatar
TV tire pressure
Michelins LTX 275/65R20
What is the proper tire pressure for towing?
Right now, I put in 45 psi but it's jst a guess
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 07-31-2012, 09:18 PM   #2
Look at the tire sidewall and inflate to max pressure stated on the tire.
Old 07-31-2012, 09:51 PM   #3
Brigitte
boubou's Avatar
Max pressure is 80 psi :O
Superglide 2700
Timbrens
Old 07-31-2012, 11:52 PM   #4
wyo700's Avatar
What kind of TV do you have.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 08-01-2012, 01:15 AM   #5
Just a member
kandl's Avatar
Brigitte, those tires are sooo overkill for your Ram 1500. Max combined load capacity of these particular Michelins is 15,000 lbs @ 80 psi - that's over 8,000 lbs more than your truck's GVWR. Notwithstanding, and to answer your question, 45 psi would not be too far off the mark. You need at least that much pressure to get a E-rated tire to make a decent contact patch with the asphalt.
What happened to the Shasta?
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 08-01-2012, 05:05 AM   #6
Brigitte
boubou's Avatar
I had very little to choose from for LT tires due to the size. I thought about changing for 17 but after researching all options, staying with the 20's seemed to better way. Wish I had known all that when I bought the TV.
Shasta was a good TT but after a few trips, we decided that the layout was wrong for us. We usually take trips lasting 5 nights or more and we got cramped (especially when we brought sister in law with us). The dinette U shaped booth dis not work at all for us! It's pretty and large but the seat on the back wall was only large enough for a child. So to watch TV, one had to sit on the bed.
All this time, we have not wanted a longer TT. We insist on not storing TT away and parking it at home. We wanted more space but not longer so we got a small 5th wheel. 25'10" total but much more space. Bathroom is smaller but leaves more room for living area. Got up pull out couch with airbed, a nice large dinette booth I can look out of (Placed on passenger side, with large picture window) and a lot more counter space.
Long story short, i was not comfortable with the original TV tires right from the get go back when I got the Shasta, but did not change right away. They were Goodyear Wrangler HP 275/60R20 and felt terribly soft even at 42psi (max 44)
Superglide 2700
Timbrens
Old 08-01-2012, 06:15 AM   #7
Herk7769's Avatar
Such is the problem with P type SUV tires.
IMO you should be running those "E" rated tires at 60PSI on your 1500
My Michelin "E" tires are run 60 PSI front; 70 PSI REAR when I am not towing (I have a 3/4 ton class truck). And run 70PSI front; 80 PSI rear when the camper in on my back.
HAM CALLSIGN - KC3FFW
Old 08-01-2012, 10:30 PM   #8
Brigitte
boubou's Avatar
Should I worry about the rims with 60 psi in tires?
Superglide 2700
Timbrens
Old 08-01-2012, 11:34 PM   #9
Just a member
kandl's Avatar
That's a very good question. You have these wheels?
Old 08-02-2012, 05:02 AM   #10
Brigitte
boubou's Avatar
Yes
Superglide 2700
Timbrens
