Old 07-26-2013, 11:00 PM   #1
dj3spots's Avatar
Under truck bed vs. in truck bed hitch mount rail... And what hitch should we get
Once again I'm checking in with the forum. We ordered a new fiver - installing the fifth airborne pin box with reese sidewinder. I want to use an under truck bed rail system so we can use more of the truck bed. DH thinks the in bed rail system is fine. The truck is rated for up to 17300lbs. I think the Reese Elite 18k hitch, we'll be able to pull something heavier should we need to and be able to use the truck bed with the under bed mounting system. DH thinks the Reese R16k is enough hitch and doesn't mind the in bed rail system. We both agree we don't need a slider since we're getting the Reese sidewinder. I'm thinking safety and options; he's thinking safety and we don't need more options. Help? Are there some better hitch options? Thanks in advance.
dj3spots is offline   Reply With Quote
Old 07-26-2013, 11:32 PM   #2
Fulltime family RVer
Personal opinion here- I didn't want to deal with rails. I use my truck for everything from landscape projects at home and family to moving furniture for myself and family. I just felt life would be simpler without rails.
However, I'm sure lots of people have rails and have no issues with it.
ependydad is online now   Reply With Quote
Old 07-27-2013, 12:40 AM   #3
Have the Reese 16K hitch with rails in the bed. No problems once I cut (4) 0.075" thick shims and took the slack out of the legs where they sit on the rails which tightened up the 4 pins holding the legs to the rails. Before I did that, there was a slight banging when stopping or starting. Once the shims were installed, no noise. I use the Reese Sidewinder Hitch and made my own wedge. Love the Sidewinder as it also allows me to use a modified Undercover hard tonneau cover while towing which covers the entire bed front to back and side to side. If I want the full bed empty, I either pull 4 pins and slide the entire hitch out and sit it on a creeper or hook up to the trailer, pull 4 pins and leave it hanging on the pin box. No problems with rails in the bottom.
ID:	36272   Click image for larger version
ID:	36273   Click image for larger version
ID:	36274   Click image for larger version
ID:	36275   Click image for larger version
Old 07-27-2013, 05:42 AM   #4
Camper Less Camping
Cajun Po-Boy's Avatar
I went with rails, have not been a nuisance when using our bed for other hauling projects
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-27-2013, 09:59 AM   #5
jevanb's Avatar
superglide with the super rails, just remove hitch,, pull pins, bed smooth
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
