Old 07-03-2013, 10:03 AM   #11
Originally Posted by jabres View Post
anyone on here towed with a suburban 2500 6.0 3.73rear end?
I would have to guess it will handle my #6500 pound loaded camper much better
Never towed with one, but no doubt it will handle your trailer much better than the 1/2T with the smaller engine regardless.
Old 07-03-2013, 07:04 PM   #12
RFK
RFK's Avatar
I have a 2011 2500 HD with the 6.0 and 3.73 rear and the blue ox WD hitch towing a 30 foot toy hauler. With a full tank of water, 20 gallons of gas and the two bikes it weighs in at just under 9000 lbs. and tows just fine. I know it's not the Suburban but should give you a good idea on what will be comfortable at highway speeds. Hope it helps, stay safe
Ray & Barb
2012 Sierra Duramax 2500HD 4 x 4
2013 Forest River XLR Hyperlite 27 HFS
2007 Harley Electra Glide Classic
RFK is offline   Reply With Quote
Old 07-03-2013, 08:09 PM   #13
Batts-toy's Avatar
Hey guys I need a little advice here. I currently own my 26' 2008 forest river wildwood tbss travel trailer weighing in at #5880 empty. Loaded down I am around #6500. I currently tow with a 2003 Chevrolet Tahoe 4x4 5.3 with 3.73 rear end and I am looking to replace it as it just does NOT have the power, and I wont take it on trips pulling the travel trailer very far.
My tow capacity on the 2003 Tahoe is#7400 pounds which is a joke cause there is no way I could safely tow that much.
SO I am really close to buying a 2005 suburban 2500 model with the 6.0 gas motor and 3.73 rear end... I am having trouble finding a "true" towing capacity for this vehicle.(the dealership does not have the owners manuel)Its really hard for me to believe where I am reading in a few places the towing capacity for this 2500 suburban is ONLY 7600 pounds when my little Tahoe 1500 model with the smaller motor is at #7400??
Anyone have some advice or experience on this? I realize a diesel would be the best for pulling but that's not in my budget right now...
Will this 2005 suburban 2500 6.0 3.73 be sufficient for pulling?
Thanks, in advance
Have you actually weighed your TBSS? I have a 26' TBSS (2013 & factory numbers are similar to your stated weights) myself and when I load up (I'm not over doing it either) and fill the fresh water tank I weighed in at 7080 pounds add my 2013 Tundra with some firewood in the back I come in at 13000 pounds for both. Only suggesting you may be heavier than you think if you haven't weighed the rig, don't believe the factory numbers.
Be safe and enjoy whichever route you go on the TV.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 07-03-2013, 08:46 PM   #14
hey rfk
hey rfk,
Thanks for all the info, helps a lot. Do you tow in the Tow haul mode?
What is the weight of your toy hauler?
jabres is offline   Reply With Quote
Old 07-03-2013, 09:08 PM   #15
wyo700's Avatar
Thanks for your post. Have you done much towing with your 6.0 work truck?
The two reasons I want to upgrade to the 2500 are for the little extra "umph" in the motor power. Not looking for a extreme power machine just something to help me keep up to speed on ighway with my fully loaded #6500 camper.
Also, was wanting the 2500 model so I can finally feel like my tow vehicle is in control when towing and not my travel trailer in control like it is now with my Tahoe.
Yes I have towed quite a bit with it. The most I tow is a 16 foot flat bed with a Honda big red on it about 3000 pounds all loaded and my truck weighs about 7700 pounds so only about 11000 gcwr. So not much of a load and the trucks struggles more than I thought it would at times. I would expect better from a 2500hd that is supposed to be good at towing. And I the Ac is on it is even worse. I am not trying to convince other wise. I'm sure the 6.0 will work for you. I'm just letting you know what I have experienced. And because of my time with the truck and because of other reasons I would never buy one.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 07-03-2013, 09:56 PM   #16
RFK
RFK's Avatar
hey rfk,
The toy hauler is 6100 empty and the usual load puts me up about 9000 lbs my truck is rated to 9600 lbs according to GM. It does have the tow package including the trans cooler but its all stock. If I'm on relatively flat highways in normal drive and use the tow / haul mode on hills and steeper grades. It does wind it up a bit to about 3500 rpms but doesn't sound like it wants to launch out from under the hood everything stays cool engine about 220 degrees with 40 on the oil pressure. The tow / haul does keep me off the breaks a bit on the downhill runs
Ray & Barb
Old 07-03-2013, 11:23 PM   #17
batts-toys-
Thanks for reply-
Say the manufacturer weight sticker inside myTBSS on the door panel is in-correct stating #5880, and say my loaded weight is right about yours at #7000 I would think this suburban 2500 w/ 6.0 and 3.73 would do the job with the tow capacity being at 7,600? (I am really shocked tow capacity is this low with the 2500 suburban, my 1500 Tahoe w/ 5.3 was only 200 #'s less at #7400 which was BS)
It blows my mind my little Tahoe w. the 5.3 and 3.73 could be as much as #7400...
What is the towing capacity of your Tundra? I always felt when towing with my Tahoe, that the TBSS was in control and not my Tahoe, the Tahoe being so light and small wheel base....
Comments?
Old 07-04-2013, 12:12 AM   #18
wyo700's Avatar
I have a tundra crew max and the tow capacity is 9000 pounds it was 10000 at first but toyota is the only manufacturer to follow the new j2807 towing standards. My toy hauler all loaded weighs about 7000 and my tundra pulls it very well. I am very happy compared to my old Titan.
2013 Toyota Tundra
Old 07-04-2013, 06:58 AM   #19
Dave_Monica's Avatar
As mentioned in a earlier post, the towing capacity is 9700 lb not 7600. I don't think you'll have any issues.
Dave
Old 07-04-2013, 08:36 AM   #20
Batts-toy's Avatar
batts-toys-
Thanks for reply-
Comments?
I have to agree with you about questioning the suburban numbers you would think it would be higher on the 2500. I agree with Dave where he looked it up at 9700#, check the chart Dave provided and even look into it further to make sure you are comfortable with everything before you jump but like Dave says I too think you will be fine with it. A short wheelbase TV can make things feel pretty 'sqirmy' like I said the TBSS is heavier than you may think. I assume you are using a weight distribution hitch with sway control.
2013 Tundra 4X4 Double Cab = 9700# tow capacity and 16,000# combined weight rating.
10,000 pound Pro WDH with 2 friction type sway bars, the Tundra tow package includes computerized automatic sway control.
