Old 07-04-2013, 05:06 PM   #31
Originally Posted by rockfordroo View Post
Here's your owners manual: http://www.vita-motors.ru/cars/chevr...ahoeGMT800.pdf
See pg 4-66; you're probably at 7400 lbs.
C-2500 (2WD)*6000 V8 3.73 7,900 lbs (3 583 kg) 9,900 lbs (4 490 kg)
Old 07-04-2013, 07:47 PM   #32
I assumed he would get the K-2500 (not a big GM guy, so not sure what the diff is between C & K). The 9,900 is for the 4.10 rear end; he said 3.73.
Old 07-04-2013, 08:00 PM   #33
RFK
RFK's Avatar
Only because I have one. GM C is 2WD K is 4WD ;-)
Ray & Barb
2012 Sierra Duramax 2500HD 4 x 4
2013 Forest River XLR Hyperlite 27 HFS
2007 Harley Electra Glide Classic
RFK is offline   Reply With Quote
Old 07-04-2013, 08:12 PM   #34
I see.
I've just bought a 2009 Silverado 1500 4x4, so I guess it's a K? But the same towing table in MY owner's manual (which is 10 pages long, BTW!!), never says C or K.
Old 07-05-2013, 12:21 AM   #35
so back to question A. The potential vehicle I am looking at is a 2005 Chevrolet suburban K 2500 4X4 6.0 motor with 3.73 rear end. Now look like towing capacity is ONLY 7,600.... Will this handle my empty weight #5880 pound travel trailer? loaded weight probably around #6500?
How can it even be possible my 2003 Chevrolet Tahoe 1500 4x4 3.73 towing capacity be all the way at #7400 when this 2500 suburban is ONLY 7600? Going from a 1500 to a 2500 with a 6.0 versus a 5.3 and I can only tow #200 more pounds?
This makes no sense again....
jabres is offline   Reply With Quote
Old 07-05-2013, 12:29 AM   #36
Denver, CO
garbonz's Avatar
Nope it doesn't, but that's the way it is.
2007 Chevy 2500HD Classic LBZ Duramax/Allison (Stock)
2005 Bigfoot 1500C8.2 AWESOME
Old 07-05-2013, 01:38 AM   #37
Oklahoma Proud
MillerTime's Avatar
I see.
Its the identifying letter in the vin # for the option. ie-GCEC.........OR GCEK.............Those are the 2 most common beginning digits on gm vehicle (truck type-not car) vin# (at least since the '90s) but the c & k was used for decades before that as an identifier.
Old 07-05-2013, 01:51 AM   #38
Oklahoma Proud
MillerTime's Avatar
We also have a tahoe same setup as yours. No way I would want to pull that much weight with one. Our boat weighing less than 4,000lb seems to be too much for it sometimes. Plus they (1/2 ton suburbans too) really are pushing the limit drivetrain wise. They are sooo heavy any kind of trailer puts a serious strain on them. Ask a transmission guy, I did ours at work and he said they just won't hold up (or will get hot, and/or puke fluid and greatly shorten thier life).
I would feel much better with you having the 2500. Much better drivetrain under them!
Old 07-05-2013, 05:37 AM   #39
Mister's Avatar
jabres... Your question intrigued me as well. People often look to 3/4 models for higher payload and tow ratings. Granted this is an SUV not a pickup but 7600 does sounds almost unbelievably low. I talked to a GM friend of mine briefly and he directed me here...
2005 Suburban 2500 LS 2WD--tow rating - Chevrolet Forum - Chevy Enthusiasts Forums
Even the Chevy fans agree with your numbers. I'd say the reason for the 100# difference between your numbers and theirs is likely 2WD vs. 4WD. I don't know this to be a fact, just an educated guess. It's on the internet so it has to be true! Bottom line and the reason for my post was this. NEVER and I mean NEVER talk to a dealership regarding towing capacities. In the past 8 years I've talked to 6 car dealerships and 3 RV dealerships about ratings. Only one ( a small RV dealership that specialized in popups and ultralite's was honest. The rest gave outrageously inflated numbers. I went with my dad 8 years ago when he brought his RAM. They tried to convince us that a 1/2-ton 4.7L w/ 3.55s could pull something like 9,200lbs! When I bought my pickup I all but punched the Chevy salesman. He kept saying "It's a Silvarado, it's pull anything." Their own books showed the towing capacity at somewhere around 4500lbs. And I had to show him that. (Before anyone asks, this was 2010 and Chevy was in the midst of their "best in class fuel economy gimik. This truck had the lowest gear ratio I've ever seen. Could be wrong but I think it was less than 3.31.) Anyway I've gotten a little carried away here, don't be afraid to pass up a "good deal" if it doesn't suit your needs. There will be other rigs That said according to what you've provided it sounds like your good as long as you keep the weight of passengers and cargo in the truck under 1000lbs. That said I haven't checked your GVWR either so you'll want to double check that first. The only thing is this really doesn't leave you a lot of wiggle room for future endeavors.
2008 F150 FX4 5.4L & 3.73s
2014 PTM Tracer 3200BHT
Yes...I've finally made it to Prime Time!
Mister is offline   Reply With Quote
Old 07-05-2013, 06:15 AM   #40
Me and my 2 friends all bought the same trailer a few years ago a 32' which I know is bigger and a little heavier but I had 08 f150 rated at 9600, one friend had 2500 suburban with 6.0 and one had 2500 suburban with 8.1. My friend with the 6.0 and I had to sell trailers after first year because it was uncomfortable towing. My friend with 8.1 still has his but says he can only go 64 max speed. After years of the single sway bar a bought the Reese dual cam knowing my trailer was at the upper limit and WOW what a difference of sway control. I know have a f250 6.8 v10 gas and a 35 fifth toy hauler that tows like a dream but if I ever go back to TT I will make sure I always have the dual cam. It's a huge difference.
CincyED is offline   Reply With Quote
