04-19-2011, 10:16 AM
upgrade pinbox??
having never towed a 5th wheel before I am not sure if I should try stock pinbox on my cedar creek 36rlts or change it out to morride or trailaire I have Pullrite 18k hitch and have to have hitch-plate adapter welded to pinbox so should upgrade pinbox pay for welding once. or have plate welded for current setup and tow for awhile. Is the upgrade worth the $$
thanks
jon
04-19-2011, 10:48 AM
Lou Amadio
Jon,
I have the 16k 3300 version of your hitch. there are several bolt on adapters that do not involve welding. In fact, there are several very good reasons to NOT weld on the "universal plate" IF a clip on version is not available for your box.
PullRite has a SAFER, STRONGER, BETTER designed hitch for you
http://www.pullrite.com/pdfs/QCCP_Fit_Chart.pdf
If you ever break down while towing your camper, you will need two tow trucks, one for your TV and one for your camper. If you welded your adapter onto your pin plate instead of bolted it on, you might have to leave your camper abandoned on the side of the road until your TV is repaired. Pullrite sells an "unadapter" conversion hitch head, that YOU would have to buy, "just in case" you broke down.
http://www.pullrite.com/pdfs/3336.pdf
Just in case folks did not know, they also now make a 3 inch riser kit for high sided pickups.
http://www.pullrite.com/pdfs/4408.pdf
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
04-19-2011, 11:07 AM
it is just the support brackets that need to be welded to the hitch head the plate will still be able to bolt and unbolt from the hitch head
04-19-2011, 11:14 AM
Lou Amadio
I see. Have you determined the manufacturer of the pin box on your unit? My dealer was making noises about installing the universal one when I had them check FR to see if a Lippert could be installed and FR did at no charge. I could then use the clip on plate.
http://www.pullrite.com/pdfs/QCCP%20_1screw.pdf
04-19-2011, 11:31 AM
Ok thanks to herk7769 I reviewed chart for capture plate I had the universal plate but now will order correct plate for my hitch no welding required. as to upgrading to moreride or trailaire I will see how she feels first then decide if I should
thanks
04-19-2011, 11:36 AM
Lou Amadio
Any time I can help I do the "Snoopy Feet!"
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 593 |
| 136 members and 457 guests |
| 1l243, 64c10, Acableguy06, acadianbob, accumack, acowie, autorot8, B47, backin15, backpacker3, BarrieMark, bean, bigbearZ71, BigJohn2, Bill High, Biscuit, blaisrv, bob213, brookside, buccello, campfun, CanadianMaple, Celicabob, chiro, cpaulsen, cyclepuck, dashonthedash, davidjb, ddavis662, djorgensen3, dnaraG_1M, donn, drb1256, dtb7811, dunnnc, dwcjb, Ed D, elind, f1100turbo, feerobk, Fire Instructor, Foley5000, FreedomTracker, GMS, grhodes50, h20ski, Hambonethecop, HamptonRoadsRVing, Happy Vibe, HemiCab, herdrn, herk7769, hoffkm, House97, itech, Janet H, jcinca, JedinWI, Jeep4Two, Jimmygee, Jo54, justinph, KarenS144, keep camping, kevinC, kingranch, kixonrt66, ktkoch, lami, lemoj1, lmcleister, Loopyhamil, Mad4sax, maniac28, mdamm, Medic44, mike7431, MOLRMEK, mraynie, mrscot, mtnguy, NanaKaren, NancyTX, neosporin, okdrifter, Old Jeeper, onthelake, Pa-cj5, pandkm, Papa Roo, Paul H. Eustace, polkatronron, pony express, Poppy Bill, PrairieBoy, punkaccountant, rawlus, Rbonnell, rbrandon, ResQMoore, Rest and Relax, RGH, RJHuser, rjshiflet, ronhanson, rotorhead1250, Rupert Rick, sandpiper, savdog, Sawdr73, Scriggs1, SDENN4281, sellis1053, ses, shane1234, Sockman, Steve7575, Swinks, Taranwanderer, Team Wilhelm, TheSasks, thumper, tking1866, tmmar, tncruiser, tojo70, toleworks, totallystirring, Triguy, troyt, Vette4trcr, vlite2011, vp22er, wa9b, wagon52, WJC |
| Most users ever online was 996, Yesterday at 11:04 AM. |
