06-10-2015, 08:20 PM
#21
very nice and you will like the way it pull's mine pull's my 3800 real easy with no stopping problems and mine is a srw. 14 working days left and we are off.
06-10-2015, 08:45 PM
#22
Originally Posted by 5er_tom
Ahhhh.... A real man's truck. Good for you
Coming from a 6.7 ford owner (and the 6.7 is quite stout) ya cant get a much better comment.
06-10-2015, 08:57 PM
#23
I just returned from my 1st shake down (bout 600 miles) how do i get trailer tow from light to heavy? I am at 10 gain and not a lot happening back there. Sorry to wonder from the OP's thread but my 1st Ram also.
Mike
06-10-2015, 10:07 PM
#24
On the radio. Look through the settings on there. It will have the trailer brake setup. Just put a check mark on the heavy electric box.
06-10-2015, 10:12 PM
#25
Thanks for the trailer brake heads up. I set it as you said but don't know what voltage to set it at so I put it on 8.0 volts. Guess I might have to play with the settings on it but no biggy.
Thanks for all the replys I'm still excited been loading the 5er tonight and fridg is on cooling down. Ready to go, come on Friday!!!
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
06-10-2015, 10:16 PM
#26
Mine seem's to be only able to adjust through the up/down on the steering wheel. Not the high end model. 5.0 screen. I will give it a try next time out.
Mike
06-11-2015, 06:48 AM
#27
Pg 312 of the manual (7"EVIC but no 8.4 radio)
Trailer Brake Type When this feature is selected, the Trailer Brake Type can be changed between “Light Electric”, “Heavy Electric”, “Light EOH” and“HeavyEOH”.Tomakeyourselection, scroll up or down until the preferred setting is highlighted, then press and release the SELECT button until a check-mark appears next to the setting, showing that the setting has been selected. Refer to “Integrated Trailer Brake Module” in “Starting And Operating.”
06-11-2015, 07:00 AM
#28
Any thoughts as to where I might set the brake controller voltage on the brakes for 18,000 lb. 5er.
06-11-2015, 07:47 AM
#29
Mud I have a 13500k 5ver and am set at 3.5 with a Ram 3500.
06-11-2015, 07:57 AM
#30
Hey thanks that gives me a starting point with 18K I'll start with 5v and see how it does. Thanks again CSTOVER
06-11-2015, 08:20 AM
#31
Love my 2015 Ram 3500 Dually
Have the 6.7 liter Cummins with Aisin transmission, air suspension and factory 5th wheel option. Installed the B&W 25,000 lb. 5th wheel hitch. Am towing a Cardinal 3850 (40' and about 16,300 lbs.). Have taken 2 trips, all on the east coast. Most times I don't even know the trailer is there. Our trip mileage is averaging 11 MPG.
06-11-2015, 08:26 AM
#32
Thanks CT3850 that's exactly what I like to hear. Hope my new one does as good, mine also has the factory 5th wheel option and Aisin tranny
thanks
06-11-2015, 06:02 PM
#33
After a recent trip where I almost lost all because of 2 broken studs in 1 wheel decided to trade-in my Tundra for a GM 2500HD/Duramax /Allison/Diesel fully loaded, I'm pulling a Prime Time 290RLT and now have realised its too much for the Tundra, what i'm asking is any advantage to keep my hitch a Husky Adjustable EZ roller 16K.
06-11-2015, 06:04 PM
#34
Thanks CST for your help.
06-11-2015, 06:15 PM
#35
Clade. You towed that beast with a Tundra? I'd like to see a pic of that if ya don't mind.
06-11-2015, 06:50 PM
#36
This is a pic of the wheel it cost $311. us dollars at a Toyota dealer to fix everything in regards to the wheel brake etc. The other is at the camp site Lake Osprey Alabama
06-11-2015, 07:14 PM
#37
Nice set up.
06-11-2015, 10:46 PM
#38
depending on the load I set mine between 6 and 6.5 for my trailer.
06-13-2015, 07:50 AM
#39
Headed out Friday morning as planned with a full load of about 17,000 lbs. I set the brake controller to 5 but raised it to 5.5 and it worked perfect. The truck had no problem at all towing my 42' Columbus up and down the rolling hills. I set it to tow/haul and set the cruise control to 65. Stopped and added 30 gallons of fuel to the Toy Hauler fuel tank and headed out non stop to our destination. Truck drove smooth and had plenty of power left over. I loved the engine brake also that worked great I never had one of those before WOW. I thought the Aisin tranny was nice and and it down shifted when it needed to and the trans temp was 172 deg. The new Cummins 6.7L got 11.2 mpg towing 17k thru the rolling hills of East Texas. I really like the upgrade of the new Ram and don't miss my 15 yr. old Ford 7.3L. LOL We are planning our next trip already. Love the truck!!!
06-13-2015, 08:03 AM
#40
Nearly a duplication of my 2007. I tow all day using my cruise control and hardly know the mountains are there.
