Old 10-04-2016, 11:38 PM   #131
Crookedread
crookedread's Avatar
I think you missed the point. Great that he passed along a message and thought, but could have made it without the advertisement. When this forum becomes an advertisement for legal services I will move on!
Crookedread
2016 Duramax
2011 Stealth 2312
crookedread is offline   Reply With Quote
Old 10-05-2016, 07:35 AM   #132
Originally Posted by B and B View Post
They do. If you order the Camper Package in the F 250 you get the extra spring but they are a different rate between 250 and 350. I just bought a FX 4 F350 that has extra heavy spring in the front with a snow plow package and the back too.
I'm not sure this is the case(different spring rate), but it could be. Regardless, a set of air bags would place the F250 over the F350 in stability and add 2 more points of load distribution on the frame.
Old 10-05-2016, 07:55 AM   #133
CaptnJohn's Avatar
Originally Posted by OldCoot View Post
OP is so happy for you, 5 new Fords is less than 2 yrs.
Actually only 3 in 17 months. 4 in 3 years if you count the suv. Still have all but 1 of the 4.
Old 10-05-2016, 09:01 AM   #134
Originally Posted by tbln930 View Post
That half tons have less accidents than larger trucks pulling rvs. Statistics don't often cooperate.
I'd like to know where you got this from?
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
Old 10-05-2016, 10:58 AM   #135
Nope. The rear spring pack is the same.
325BH is offline   Reply With Quote
Old 10-05-2016, 11:55 AM   #136
This is correct. I just went to fordparts.com and looked up my 2015 F250 rear springs, and it clearly states that the same spring is on the SRW F-350.
A couple of examples from the descriptions:
"Rear Spring Ford 250 Series Wide Frame (Pickup) With Single Rear Wheels Ford 350 Series ; 4WD, Ford 250 Series, Single Leaf Rear Auxiliary Spring"
"Rear Spring
Ford 250 Series Wide Frame (Pickup) With Single Rear Wheels Ford 350 Series ; 2WD, With Gas Engines, Ford 250 Series, 142"/3607MM Wheelbase, Less Rear Auxiliary Springs, 156"/3962MM Wheelbase, 158"/4013MM Wheelbase, 172"/4369MM Wheelbase"
Old 10-05-2016, 07:19 PM   #137
Crbacsw's Avatar
Metal valve stems?
Originally Posted by rsdata View Post
Load range E tires, when you are ready for an upgrade... don't forget to get metal valve stems installed at the same time...
less flex in the sidewall gives less sway to the rear of the truck...
air them nearly to capacity for towing, then drop 20# or so when driving for a less bumpy ride
Why are metal valve stems recommended?
Crbacsw is offline   Reply With Quote
Old 10-05-2016, 07:32 PM   #138
They are stronger.
Old 10-05-2016, 07:54 PM   #139
GreenImp's Avatar
Send a message via MSN to GreenImp
The valve stems need to be rated for at least as much Air Pressure as the tires are. If you are upgrading factory tires to a higher load range, then your valve stems are most likely not rated high enough. Metal stems are "high pressure" stems.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 10-05-2016, 11:20 PM   #140
rsdata's Avatar
metal valve stems are not very expensive ($4-$6) when your having tires installed, they are good for higher pressures that load range E tires (up to 80 #) use and if you have thru the valve TPMS sensors they will not flex the valve stems leading to premature failure...
2014 Shamrock 183
2014 RAM 1500 SLT Crew Cab HEMI 3.21 8 Spd 4X4
upgrade
