Old 09-29-2016, 06:04 PM   #31
I was referring to the OP: with 7800 dry any extra cargo in TT & TV his payload would be challenged.
Seachaser186 is offline   Reply With Quote
Old 09-29-2016, 06:07 PM   #32
john5646's Avatar
06 Titan pulling 9000 plus. Mods that helped me.
Firestone ride rite air bags
Electric tranny cooler, in addition to factory cooler. Note the factory cooler is not a lot bigger than an electric water heater element.
Equalizer hitch 1200 lb bars
Modified with friction sway control. Click image for larger version
Name:	ImageUploadedByForest River Forums1475190341.723072.jpg
ID:	121651Click image for larger version
Name:	ImageUploadedByForest River Forums1475190375.106047.jpg
ID:	121652Click image for larger version
Name:	ImageUploadedByForest River Forums1475190417.273874.jpg
ID:	121653Click image for larger version
Name:	ImageUploadedByForest River Forums1475190469.329129.jpg
john5646 is offline   Reply With Quote
Old 09-29-2016, 06:19 PM   #33
Originally Posted by goduc View Post
So are you over weight with the 5r? Just because you have towed all over that doesn't make it safe. More likely lucky. If you are afraid of the Rockies then you're definitely under trucked.
Not afraid of the Rockies, went there in the 72 El Camino and again in the 81, as they say, "Been there, done that." We winter in FL and have no desire to go west of the Mississippi anymore. Just because I don't tow with a Mack doesn't make it unsafe. Have no desire for a bigger truck when what I have does just fine at 55-65 mph. BTW, pin wt is less than 1100#
Old 09-29-2016, 06:28 PM   #34
Coachman 312BHDS
The payload/rear axle is the issue - even if it is the Titan XD.
That is exactly where our TT started empty. Ours loaded and weighed is 9080. You need a very good WDH like a Husky Centerline TS to transfer enough weight to the steering axle and trailer axles.
2016 Coachmen Freedom Express Liberty Edition 312BHDS (37')
2014 F150 Lariat 3.5 V6 Eco Screw max tow - Century hard cap - Husky Centerline TS WDH
tbln930 is offline   Reply With Quote
Old 09-29-2016, 08:25 PM   #35
So 12% of 9080 is 1089 plus the hitch weight goes towards payload. Better check your payload or cargo carrying capacity posted inside your driver door.
Old 09-29-2016, 08:42 PM   #36
Crusadernoob's Avatar
I would do as many have stated, LT tires, trans. cooler, I would also look into a rear sway bar. Without a trans. temp gauge I would change the fluid often, I change mine once a year, I also change all my fluids once a year. It won't hurt anything to make sure it is in good shape, heat kills. Good luck with your set up, and be safe.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!
Nights camped in 2014 37
Nights camped in 2015 40
Nights camped in 2016 39
nights camped in 2017 7
Crusadernoob is offline   Reply With Quote
Old 09-29-2016, 09:04 PM   #37
Originally Posted by cphubert View Post
It is not about pulling but rather stopping it.
I did not mention it, but this is the main reason why I traded my Titan. I was also over on tongue weight, which I believe the OP might be as well.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2016: 19 nights
Miles traveled in 2016: 2,575
uhduh camping is offline   Reply With Quote
Old 09-29-2016, 09:31 PM   #38
Coachman 312BHDS
What is 12% ? I weighed it. Did you not read all of the posts?
Old 09-30-2016, 12:56 AM   #39
The man is still here to talk about it, I'd say he's pretty safe, luck always runs out at some point. I was asked last week if I wanted to go to California, have no desire so I said no way, am I undertucked?? Man I hope not.Click image for larger version
Name:	ImageUploadedByForest River Forums1475214958.583396.jpg
jerky is offline   Reply With Quote
Old 09-30-2016, 10:30 AM   #40
Originally Posted by tbln930 View Post
My dealer says about 80% of the 250s they weigh with 5ers are over payload.
If we assume that your % is correct, which I don't doubt from my own observation, and then we consider the rarity of accidents involving 3/4 tons pulling RV's..... the only logical conclusion is?????
upgrade
