Old 08-30-2016, 10:49 AM   #11
lesptr's Avatar
Thanks for all the great info guys. It is very much appreciated!
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 08-30-2016, 06:14 PM   #12
Jack350's Avatar
Originally Posted by donniedu View Post
Squat? Dont worry about it until you actually get the trailer home and loaded for a trip. BTW, gooseneck? Does the trailer mfg know this? Using one could void your trailers frame warrenty. Generally speaking fifth wheel frames are not designed or strengthened sufficiently to support a gooseneck setup. Second, does this fiver have sufficient cut to allow for tight turns without hitting the truck? I think you have way more to worry about than squat.
The Andersen Ultimate is a great choice. I have been using for two seasons and have no problems. It is not a gooseneck hitch. It is a fifth wheel hitch and attaches at the pin just like all 5th wheel hitches. At 32 pounds it also increases your ability to carry more gear.
2012 Crusader 26RLD, 2017 F-350 4X4 6.7.
Hayes Autoformer, Correct track, Maxxis 8008E, Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 08-30-2016, 06:18 PM   #13
pjones1969's Avatar
Another vote for the B&W Companion, I had one in my 2012 F-350 SRW short bed, didn't even opt for the slider and had no issues on clearance with a Palomino 32bhok, I added Timbrem SES bumper stops before I picked up the trailer so don't know what it would have looked like without them, advertised hitch weight is 1872 lbs. empty.
2013 Palomino Sabre 32bhok
2012 F250 FX4 6.2
2013 Sabre 32bhok-6
2012 Ford F250 6.2
B&W Companion
pjones1969 is offline   Reply With Quote
Old 08-30-2016, 06:48 PM   #14
lesptr's Avatar
More great info, thanks again all.
2015 F350 6.7
Old 08-30-2016, 09:08 PM   #15
Have an Anderson Ultimate hitch on GMC 2500HD and now on a 3500HD. Some squat on the 2500 but hardly any on the 3500. Nice and quiet towing . Very light hitch to remove and install.
Mahlstedtd is offline   Reply With Quote
Old 08-30-2016, 09:45 PM   #16
lowbubba's Avatar
Have used the Andersen hitch this year, no issues. I am pulling with a GMC 2500 HD I put Sumo Springs on mine and are very happy with them. No air, no brackets, just install and go. Helps with rebound after hitting a bump or a Kia.
Lowbubba
What could go wrong?
lowbubba is offline   Reply With Quote
5er
