Old 08-29-2016, 07:30 PM   #1
lesptr's Avatar
Upgrading from TT to 5er
The big question is,...what have I not considered???
I have a 2015 F350 SRW super crew 4wd short bed (6ft 8 inches) that I take in Wednesday morning to get the B&W turnover gooseneck and wiring harness installed. I will be ordering the Anderson Ultimate hitch here shortly, unless you guys talk me into something else. I've chosen a 5er that at max gross wt will keep me under max combined, and max pin (at 25%). What I don't know is how much squat I will get with 3k pin weight. Will airbags be needed to level the truck? Never having owned a fifth wheel, what have I not considered?
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is online now   Reply With Quote
Old 08-29-2016, 07:44 PM   #2
Squat? Dont worry about it until you actually get the trailer home and loaded for a trip. BTW, gooseneck? Does the trailer mfg know this? Using one could void your trailers frame warrenty. Generally speaking fifth wheel frames are not designed or strengthened sufficiently to support a gooseneck setup. Second, does this fiver have sufficient cut to allow for tight turns without hitting the truck? I think you have way more to worry about than squat.
donniedu is offline   Reply With Quote
Old 08-29-2016, 07:56 PM   #3
lesptr's Avatar
With the Anderson it will clear, and ,...
Sent from my iPad using Tapatalk
2015 F350 6.7
Old 08-29-2016, 08:01 PM   #4
Ford Idaho's Avatar
There were some reports of the Andersen Alloy hitch having some problems with cracking welds/metal.
I have not seen if it has been corrected.
I would get the B&W Companion to go with the turnover.
Old 08-29-2016, 08:07 PM   #5
lesptr's Avatar
I'll research that.
2015 F350 6.7
Old 08-29-2016, 08:11 PM   #6
CaptnJohn's Avatar
X2
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 08-29-2016, 08:19 PM   #7
I have a 2016 F350 SW with a trailer that has close to 3K pin weight and the truck sits level.
Signguy71 is offline   Reply With Quote
Old 08-29-2016, 08:35 PM   #8
lesptr's Avatar
Good to know. Thanks.
2015 F350 6.7
Old 08-29-2016, 09:26 PM   #9
CaptnJohn's Avatar
2016 F350 swd 4x4 with a little over 2800 on the pin and the drop is not noticed.
Old 08-30-2016, 05:08 AM   #10
CWSWine's Avatar
I have 2015 F350 Diesel 3180 pin and the truck sit perfectly level. Mine is about 1/4 inch from the overload springs contacting the stops and I have found if you hit a bump you get rebound off of the overload springs. I installed airbags not get level but to keep the truck from contacting the over load springs. Try it first and see what you get.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
5er
