05-06-2016, 08:12 PM
Upgrading tow vehicle
Hey I'm on a fact finding mission. The DW and I are thinking about upgrading our tow vehicle in the near future and I'm looking for specific info. What I would like from all of you here on the forum is to list what kind of TV you have engine size,axle gear ratio,gas mileage with and without the camper, towing capacity,payload etc. Please let's not give opinions or personal feelings into this I'm just looking for facts so we can come to a decision on what to look for in a truck,thanks
05-06-2016, 08:19 PM
to help you get answers pertaining to what you are looking for, 1/2, 3/4, or 1 ton? Gas or diesel? What are you looking to tow?
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
05-06-2016, 08:42 PM
2015 ram 2500 get 8 mph towing an 8000 pound tt and 16 on the highway as my daily driver. 373 gears. 6.4 hemi
2015 ram 2500
2016 Cherokee 274dbh
05-06-2016, 08:50 PM
We are thinking 1/2 ton we have a 23LB which weighs less than 6000lbs. If we decide to change TTYL in the future chances are we will downsize to something smaller.
05-06-2016, 08:56 PM
Oops sorry I missed the gas or diesel part of your question I prefer gas over diesel just cause I've never had one plus I don't know anything about them either plus DW doesn't like the smell. Also I should also mention we want something that will tow well in the mountains.
05-06-2016, 09:28 PM
I have a Diesel and do not smell a thing. Use gloves when refuelling. If you want power in the mountains you need torque created by a Diesel Engine. Also exhaust brake is very helpful going down slowing saving the brakes.
B and B
05-06-2016, 09:52 PM
Saying "gasoline engine towing well in mountains" caused my head to hurt. Those two attributes dont play well together. Ive had both. Ive never owned a truck that had the power this diesel does. Its amazing.
My diesel doesnt smell any worse than my gasoline engines, and i never use gloves to refuel with....probably should, but dont. Diesel engines are more expensive initially, but, with good care, will last for hundreds of thousands of miles.
Good luck,...have fun...
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
05-06-2016, 10:00 PM
2016 Tundra SR5, 2WD, Double Cab, Standard Bed
5.7L, 381 HP, 401 torque
4.30 Rear Diff
10,300 Max Towing
1,715 Max Payload
13.5 mpg City, 9.8 mpg Towing (per the computer). Actual Highway is Unknown.
TT: 2016 FR 23LB
Dry 3,814
Max Cargo 978
GVWR 4,792
2021 Silverado RST Z71 4x4 6.2L
2021 Flagstaff Micro Lite 25FKS
USMC (Retired) '70-91
05-06-2016, 10:44 PM
A good question to ask yourself is how much will you be camping/towing vs using this as a daily driver. The get in costs and maintance are largely different between gas and diesel.
Pulling 7500lb 31ft with 2011 tundra with 5.7. Upgraded intake and exhaust. Can pull at altitude 9000 ft. But I plan ahead and make sure it is in powerband entire time. 12 around town and 8-9 towing.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
05-06-2016, 10:54 PM
If you're looking for a 1/2 ton that tows well in the mountains, then you'll want to look at either the F150 with an Ecoboost or consider the 1/2 ton Ecodiesel Ram.
John Taylor
2019 Newmar Bay Star 3609
2018 Cardinal 3350RLX - sold
2013 Cardinal 3030RLS - sold
05-06-2016, 10:58 PM
My Ecoboost just pulled a 8,000 pound 5er up to the Eisenhower Tunnel at 60 mph.
Just sayin . . . . .
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
05-07-2016, 12:07 AM
I know you said that you wanted facts only but I think that this is going to come down to what truck you like best. If you choose between Dodge, Ford or Chevy/GMC there are all positives and negatives you have decide what truck you like the best. I pull my 26tbud with a 2012 Silverado with the 5.3 it tows just fine, I won't win a race over the Cascade Mt's here in Washington but we will go up it 55 to 60mph with no problems. Our total weight with people, trailer and gear is around 8000lbs and we get 10mpg towing in most conditions.
05-09-2016, 09:27 PM
I pull a 26RR (6800 loaded) with an 08 Escalade ESV, and I am a huge fan of the GM 6.2. About to turn 160k and no issues so far with routine maintenance. Comes with a 3.42 G80 rear end, AWD, and I get anywhere from 7-10 MPG depending on terrain while towing, and 17-19 unloaded.
2016 26RR and a 2018 OR371MBH
05-09-2016, 10:25 PM
Ambassador
NEw 2016 F250
We just upgraded to an F250 Crew Cab 6.5 ft bed. Our TT weight approx. 7000 lbs. I set up the WDH as soon as I drove it off the lot.. Took the TT through the Smokies barely new it was there. This model has the integrated proportional break controller which I found to be super nice. I got 8.4 mpg avg going over the mountains, and 9.5 mpg on the rolling hills going home. I get 11 to 12 unloaded. It has the 6.2 liter gasser. Entry cost for me was pretty low, I didn't need the nicest truck on the lot, I got a plain XL with a few options (cloth seats, cruise control, Bluetooth etc...), I got out for 35K tax, tag, and doc fees. Tow Capacity is about 12K with the gas engine, Weighs: 9900-lb GVW with a 3959-lb Payload. I have the standard 3.73 gear option.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
05-09-2016, 10:56 PM
In 2013 I bought a 2 year-old Ram 2500 CC ST w/5.7 Hemi for only $14K. IMO the newer gas engine/tranny technology handles the eastern mountains just fine. My Hemi had no trouble hauling our combined TV & TT weight of 15,000 throughout the Smoky Mountains last summer. Most of the time the tranny dropped just one gear & I had plenty of peddle left. When we head out West I know I won't be the first one up the hill - but for the money saved I don't care...
Besides a great price, my 2500 has a payload of 3,000 which means it can handle our TT's tongue weight of nearly 1200, family of 5 & 1 dog that weigh-in around 700, plus a fiberglass cap that keeps our firewood, bikes, tools, etc. safe & dry throughout our travels... I get 8-9 mpg towing and 16-17 on my daily commute.
If you drop-down to a 1/2 ton, especially one loaded with extras, you lose so much payload that you have to always monitor how much you are adding to your TT's tongue weight & how much stuff you are hauling in the TV, including people...
2011 RAM 2500 ST Crew Cab 5.7 Hemi
2011 Primetime 3150BHD Touring Edition
Days camped in 2018- 25
2017- 31; 2016- 36; 2015- 37; 2014- 31
05-12-2016, 03:08 PM
2013 Ram 2500 CTD, 3.42 rear, Automatic, 4wd. 2375# payload.
31(ish)' Heritage Glen TT. 10,000# loaded or there abouts, TW I also guess at 1100/1200# loaded. Set the WDH right and I dont even know the TT is there.
Its my daily driver. As for fuel mileage, no idea. It has taller and wider tires on it, so that throws things off. Ive never hand calculated the numbers, but on a guess, high teens (unloaded).
FWIW my 2010 F150 Lariat (5.4, auto 4wd SCrew) had a payload of 1050#.
05-12-2016, 04:24 PM
After driving home with new 13,000 lb 5'er, I'll never recommend anything short of a Kenworth for towing anything.
FROG AR-0019-242
05-12-2016, 07:11 PM
Cruiser - I'm not trying to be snarky, BUT.... don't base a $50K purchase on what I or any other internet expert says. Decide how you'll use the truck, how much and how often you'll tow, whether you plan to get a bigger trailer, and your own tolerance for towing at or near max tow ratings. Once you think you have a make/model in mind, search the owner's forums for that brand of truck (most have a towing section). You'll get a lot more specific info on a truck forum regarding axle ratios, engine size, optional equipment, real world fuel mileage, etc.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
05-12-2016, 07:19 PM
Today I had to go to the dealer to pickup my 17FQ after some warranty work was finished.
Below is a screenshot before I entered their parking lot. Sorry it's out of focus but that's showing 32.8mpg over the 22.7 mile trip on I-35 from Austin to Georgetown at an average speed of 66mph.
On the way back towing the 17FQ, I averaged 18.2mph.
This Ram 1500 Ecodiesel amazes me every time I drive it.
Specs: Lonestar Edition 3.0 turbo diesel, crew cab, 3.73 rear axle, 7950 tow rating, integrated brake controller, $33K + TT&L.
2016 Clipper 17FQ
2016 Ram 1500 EcoDiesel
2015 Jeep Wrangler Unlimited
05-12-2016, 07:20 PM
No opinions or personal feelings . you have a loaded ? to ask something like about what TV you should get .
if you want a 1/2 then you have a few options Chevy Ford Dodge toyota
all the specs for these will be on their web sites
