Old 11-12-2018, 01:31 AM   #1
Multi-Slacker
Use Cases: Gooseneck vs. 5th Wheel
Just out of idle curiosity and since I see a number of heavy trailers being hauled with gooseneck, when should one choose which and why?
TIA
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / Class V (2000 lb) Receiver
CurtPutnam is online now   Reply With Quote
Old 11-12-2018, 08:46 AM   #2
NMWildcat's Avatar
Most folks who tow their RV with gooseneck have a truck that is already set up for gooseneck to haul other trailers.
Otherwise, no real advantage one way or the other.
Scott and Liz - Southern NM
Old 11-12-2018, 09:04 AM   #3
RV There Yet?
IsleDog's Avatar
I dont have either, and dont plan to. but would you gain any usable bed space with a goose neck?
IsleDog is online now   Reply With Quote
Old 11-12-2018, 09:18 AM   #4
NMWildcat's Avatar
Yes, but not enough to warrant going gooseneck for only that reason.
Old 11-12-2018, 09:28 AM   #5
koller1509's Avatar
I agree with you if you already are set up for 5th wheel. Now if your not and had to buy a fifth wheel hitch, it might make sense to switch to a goosebox. Just be aware that not all gooseneck pinboxs are created equal or approved by Lippert. And stay away from the 5th wheel to gooseneck adapters!! A few people here have ended up with structural damage from using them and they void your warranty from Lippert.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 11-12-2018, 09:29 AM   #6
If you have a short bed then the goose neck won’t work because of clearance issues with the truck cab and trailer while in a turn. Even if you have the mid box you still may have a clearance issue at the 50 degree mark. Goose necks do ride better and are easier to connect and disconnect though. Take lots of measurements before purchasing.
Good luck!
John24RLS is offline   Reply With Quote
Old 11-12-2018, 09:30 AM   #7
koller1509's Avatar
I use a Demco gooseneck adapter plate that my 5th wheel hitch pins into. Works well but adds a lot of weight to an already heavy hitch. Luckily I have an electric hoist to remove and install it. If I upgrade I will go to the goosebox setup.
Larry
Old 11-12-2018, 09:32 AM   #8
With the B&W hitch that I have you can install the turn over ball and a gooseneck. I occasionally hit the tailgate with my pin now what would I do if I was towing with a gooseneck
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 11-12-2018, 02:54 PM   #9
I towed with a gooseneck setup that my dealer installed. My F250 was set up for towing and came with the ball insert for the gooseneck. My truck was a 6 1/2 ft bed, extended (not Crew) cab. I had no problems whatsoever, Even got pretty good at hooking it up all by myself and was able to pull right under the goose neck with the ball on the first try or very close (inches). Had a lot more bed space and no fiver hitch to store when not using. You will have to rig up a way to hook you fiver emergency brake cable but not a big deal - just find a place to put a snap hook.
2014 FR Crusader 315RST
2014 Ford XCabSD F250 6.7L
4x4 Lariat
johnruff is offline   Reply With Quote
Old 11-12-2018, 04:08 PM   #10
I just bought a new 2019 F-350. I asked the dealer to show me the towing capacity for a 5th wheel. He pulled it up on the computer and it said 27,500 lbs with a 5th wheel hitch and 35,000 lbs with a gooseneck hitch.
WilliamG is offline   Reply With Quote
5th wheel, wheel
