Old 10-23-2017, 09:02 PM   #1
Adony's Avatar
Using a Flip-Foot on Electric Tongue Jack
This past week while staying at an older state park, I came across a situation that initially prevented me from leveling the 26 ft trailer front to rear.. I never realized until it was to late that the RV paved pad, although was perfectly level from side to side, it was considerably lower in the back than where the trailer hitch was. After unhooking from the TV, and removing the wt distribution bars, I proceeded to lower the tongue with the electric jack to level the trailer front to rear.. I have the Flip Foot installed on my jack and it wanted to retract before the front was low enough to be level... at first I was going to leave it there but I went to plan B. I have a hydraulic bottle jack I carry in the TV so I raised the trailer frame up high enough so that the flip foot would retract. Then I placed wooden blocks under the retracted foots side and lowered it until the side of the foot rested on the blocks. Now the trailer could be leveled but this was a PITA.. Anyone else using a flip foot that has experienced this and how did you take care of it? Maybe removing the Flip Foot and going back to the adjustable foot is the answer????
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 10-23-2017, 09:11 PM   #2
I have one of the plastic jack stands. Sometimes I have the problem you have. In this case I have to put the flat metal plate back on the jack. It's easy on and off with a hitch pin. Doesn't take up much space when not in use.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 10-24-2017, 12:16 AM   #3
2007 WildCat 32QBBS
18CrewDually's Avatar
What you would do is before un-hooking, first flip the foot by hand to a horizontal position and hold it while lowering it. This will give you more travel to lower the tongue. Like the pic below.
18CrewDually is offline   Reply With Quote
electric
