Closed Thread
Old 07-16-2014, 01:25 PM   #21
Originally Posted by Kaadk View Post
Gotta agree with Turbs on this one. Just because they didn't bother putting barricades up, doesn't mean it's open for business. Most of the ones around here have signs that either say "Weigh station Open" or "Weigh Station Closed". Closed, means closed. If a store has a closed sign, but forgot to lock the doors, it doesn't mean I can just go in and shop.
Essentially, not the same thing. Public road vs. private property. Look at it this way, you are legally allowed to drive on a public road unless a physical obstruction is in place (i.e. baaracade, gate, etc.). Entering a private premise, with "closed sign" is called tresspass, because it is construed by the average person that a private premisis, where a closed sign is displayed, should be construed as a place of non entry.
Hope that helps. I did sleep at a Holiday Inn Express last night!
Still Kickin is offline
Old 07-16-2014, 01:41 PM   #22
I think they leave the monitors facing out to encourage responsible, law abiding citizens/truckers to voluntarily meet the legal guidelines. With a fresh load, you may not know you're over weight. But learning that at a non-enforced scale may motivate a trucker to offload a little before rolling across an enforced one and paying a fine. As a society, we save road repair dollars at the expense of a little electricity. Think of it as one of those radar trailers near a construction zone saying "Your speed is..." Better to slow down at that sign than get chased down by the trooper around the next bend.
Brian and his Girl Crew
5 bikes - one top tube
Rig: 2004 Excursion 6.0 PSD + 2009 Salem 27' TT
b_garage is offline
Old 07-16-2014, 02:28 PM   #23
Witch Doctor's Avatar
Cat scales are different then state highway truck scales to begin with. If you can not afford $10.00 at a cat scale which is divided to 3 selection, all your going to get is a total weight. If someone can't afford the cost then how do you buy fuel? Why would you even want to do it? If you do not know your total weight, then I guess you have a problem.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is offline
Old 07-16-2014, 02:51 PM   #24
B47
Originally Posted by SaskCampers View Post
The scales around here are used all the time by truckers etc when they are closed. Heck the truckers use them for rest stops as well when they are closed.
I have never seen any trucks parked at a closed weight station here in the U.S.
YMMV
B47 is offline
Old 07-16-2014, 02:54 PM   #25
Oaklevel's Avatar
As always I would check with the local state police before I used a state scale in some states when it says closed it means, closed / no trespassing. Here most of the scale pull offs for portable scales are also marked no trespassing barricades or not.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is offline
Old 07-16-2014, 02:56 PM   #26
NELA
Weezer's Avatar
YMMV
I have. Maybe it's just a Louisiana thing. (shrug)
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline
Old 07-16-2014, 03:08 PM   #27
KyDan's Avatar
YMMV
Then you must not be paying attention. I see them all the time.
BTW cat scales are less than $10 and give you 3 axle weight.
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now
Old 07-16-2014, 03:09 PM   #28
dcheatwood's Avatar
Yep weezer. All the time here.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is offline
Old 07-16-2014, 03:17 PM   #29
NELA
Weezer's Avatar
I'd rather see them parked at scales than use the on/off ramps of I-20.
Weezer is offline
Old 07-16-2014, 03:28 PM   #30
B47
Perhaps I'm not - that's why I said YMMV.
B47 is offline
Closed Thread
