Closed Thread
Old 07-16-2014, 10:06 AM   #1
Using Closed Weigh Stations?
In a post on another forum it was observed that some folks have weighed their camping rigs at closed highway weigh stations, specifically in Washington and Oregon.
Who else has done this in other states and can you provide any insight as to the process and legality of doing so?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline
Old 07-16-2014, 10:15 AM   #2
TURBS's Avatar
Trespassing comes to mind.
TURBS is offline
Old 07-16-2014, 10:22 AM   #3
I have used a local highway truck scale several times. The screen is turned around so you can see the numbers from the outside. I have never had an issue.
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline
Old 07-16-2014, 10:25 AM   #4
Depends on the station. Here in MT, some leave the scale on and you can see it from the window. Others don't. The only ones I have seen with the scale left on is the smaller stations where there is only a single or 2 pad scale. Like the ones used for primarily log or gravel trucks.
IMO, unless you have a small station that is close by and you can stop by and ask permission sometime, it is easier to just pay the $20 and go to a CAT scale. I would never try and go try and weigh on one of the larger interstate weigh stations.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is online now
Old 07-16-2014, 10:29 AM   #5
I should have mentioned that the scale was closed. I was told that the screen was turned around so the scale could be used when no one was working.
John And Mary
2013 XLR 27 HFS
Kaboom is offline
Old 07-16-2014, 10:33 AM   #6
Interesting thought. I should have clarified my post by saying a state-owned (taxpayer-owned) weigh station that does not have any barricades and does not have no trespassing signs.
Lee and Anne
Teamfour is offline
Old 07-16-2014, 10:42 AM   #7
TURBS's Avatar
I think I'll "borrow" a taxpayer owned police cruiser then....
Great logic.
There's also no sign saying..
Were closed but go ahead and use the scale.
Why wouldn't u just ask them to use it while there open?
TURBS is offline
Old 07-16-2014, 10:47 AM   #8
Not the same Turbo. You are not taking anything and if the power is on then you are not even using more electricity. If they turn the screen around so people can see it from the outside it seems like they expect people to use it. Non of this is going to help you in court but it seems logical to me.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline
Old 07-16-2014, 10:48 AM   #9
Kaadk's Avatar
Great logic.
Gotta agree with Turbs on this one. Just because they didn't bother putting barricades up, doesn't mean it's open for business. Most of the ones around here have signs that either say "Weigh station Open" or "Weigh Station Closed". Closed, means closed. If a store has a closed sign, but forgot to lock the doors, it doesn't mean I can just go in and shop.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now
Old 07-16-2014, 11:14 AM   #10
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I for my part go over almost every dot scale when it is shut down for the day/weekend and get my weights. My understanding is that in BC Canada even RV's are required to go over the scales together with heavy trucks.
I did a quick Google search and came up with a slew of information. https://www.google.ca/search?q=weigh...icial&start=10
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is online now
Closed Thread
