Old 07-01-2019, 05:18 PM   #1
Using OEM tires or switching to LT tires
I'll be picking up my new GMC Sierra in a few weeks and I'm curious to know if people pulling larger travel trailers are keeping the OEM "all terrain" tires or switching to LT tires like a lot of people who also switch out the original crap trailer tires with something a little stronger....
Big51810321 is offline   Reply With Quote
Old 07-01-2019, 05:47 PM   #2
SeaDog's Avatar
Most of the original crap trailer tires problems are due to crap maintenance by the original owner.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-01-2019, 07:48 PM   #3
No self-respecting tow vehicle will come with all terrain tires
You must have added some needless package for yours to come with them.
2020 Coachmen Chaparral 360IBL
2018 Ram 3500 SRW
AndreTheGiant is offline   Reply With Quote
Old 07-01-2019, 07:53 PM   #4
When searching for a tv we found the majority of trucks had the $2000 sport all terrain package. The proper smaller wheel tire combination is better for towing.
tomkatb is offline   Reply With Quote
Old 07-01-2019, 07:54 PM   #5
Commercial Member
Are your OE "All terrain" tires Passenger type? Not much of a tow vehicle if it is.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling)@ FMCA in Tuscon, AZ in March 2020
Tireman9 is offline   Reply With Quote
Old 07-01-2019, 08:10 PM   #6
Coach
Being all terrain does not necessarily mean that they are not LT tires. Do your homework on the load capacity of the included tires compared to what you intend to haul. In general, the tires will be rated to at least the gvwr of the truck, so if you're not exceeding that you should be fine. Would I trust that to be true? Absolutely not, I would definitely verify. All that being said, if you're buying new you should spec it with what you want.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is online now   Reply With Quote
Old 07-01-2019, 09:03 PM   #7
Grammar Pedant
67L48's Avatar
What Valley said ... the premise of the question is flawed. A/T tires are not mutually exclusive with LT tires. Most A/T tires I have shopped for in the past are, in fact, LT tires.
Last 3 trucks I've purchased came with factory A/T LT tires.
I'd be surprised if a new GMC Sierra came with P rated tires, but maybe it does.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 07-01-2019, 09:05 PM   #8
OK!
Will definitely look into this, as this will be my first ever truck purchase, I've had a few SUVs, but never a pickup truck.
Thanks!
Old 07-02-2019, 07:56 AM   #9
X2 when I owned my last TT I used a F150 Eco to tow it. The stock tires did not appear to have load ratings. So after some research I moved to load range D tires more than enough for my truck and TT. I did choose the more aggressive tread though and more than likely when time to change tire on my new rig will do the same I like the look
moose074 is offline   Reply With Quote
Old 07-02-2019, 12:39 PM   #10
Canadian Member
I agree with others that LT tires are the best option for towing, and you can get "all terrain" tires in both P (passenger) and LT (light truck) tires.
My 2016 F-250 came from the factory with Michelin LTX A/T2 tires. They're just OK IMO. When they're close to their end of life, I'll be installing Bridgestone Dueller A/T Revo 2 tires that have a much better tread design for snow and mud without being noisy on the highway. They come in both LT and P (passenger) types.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 07-02-2019, 01:10 PM   #11
ARLO
I always switch to E rated LT tires
rlocicero is offline   Reply With Quote
Old 07-02-2019, 02:17 PM   #12
Switch to E rated tires ONLY if they support the load.
My new 2017 GMC Dually came with LT A/T Tires.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy Flt Test Engineer
Splashes3 is offline   Reply With Quote
Old 07-02-2019, 05:44 PM   #13
Lins's Avatar
My brother-in-laws Chevrolet Silverado with max tow package or whatever they call it came with P-rated tires on 20" rims. He has had no problems towing with them.
Edit: We visited their campsite this weekend. He has 67k on it now and replaced 2 tires so far with - new P-rated tires! Blasphemy on this site.
2007 Rockwood 2701SS
2014 Triumph Bonneville. NH Togas, TTP Tune 3
1953 GMC 9314
Lins is offline   Reply With Quote
Old 07-02-2019, 05:53 PM   #14
D W
D W's Avatar
The 1500 Silverados & Sierras are all equipped with 18" P265/65R18 tires as standard equipment.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 07-02-2019, 06:20 PM   #15
NH Maple Maker
russhd1997's Avatar
My truck came with P metric tires and I didn't have any problems towing with them. I just replaced them with BF Goodrich All Terrain T/A KO2's. They're load range E LT tires. Overkill for a 1/2 ton truck but if I got load range D tires I would have had to pay $39 per tire more.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
russhd1997 is online now   Reply With Quote
Old 07-02-2019, 06:22 PM   #16
All-terrain tires
I could deal with all-terrain and other tough-looking-tread tires for short distances around town, but the road noise on a long trip would really be annoying. Why would anyone put up with that?
Same complaint on those "manly" exhausts.
Larry
Larry-NC is offline   Reply With Quote
Old 07-02-2019, 08:24 PM   #17
Grammar Pedant
67L48's Avatar
Interesting that so many of the GM 1/2 tons come with P-rated tires. My 2005 F-150 came with LT tires. I switched to P-rated because I wasn't towing with it. They did ride pretty nice. I then switched to E-rated LT tires, which were much rougher. So, it could be an "appeal to the masses" type of move -- more 1/2 ton drivers probably value the smoother ride over a stiffer sidewall for towing.
Never had an experience like Larry describes. A/T tires are quite road worthy and I've never had a noise problem. Very quiet in my cab. Some M/T tires can hum a bit, but I've never had a bad experience with A/T tires. And, I don't like trucks with tires that look like they came off my grandpa's oldsmobuick. I'm thinking a tan 2WD truck with Michelin all seasons. Ugh.
Old 07-02-2019, 09:03 PM   #18
I would stick with the OEM tires to see how they perform before deciding to switch to something far more expensive. We have had nothing but success with Michelin LT tires in the proper size and capacity ratings for more than 40 years.
Jakie-Boy is offline   Reply With Quote
Old 07-03-2019, 05:27 AM   #19
NH Maple Maker
russhd1997's Avatar
Larry
The BF Goodrich A/T tires that I put on my truck are as quiet as the OEM P metric tires that I took off. Because they are a heavier duty tire the truck does ride a little harder but I like that it feels more like a truck. The more aggressive tread will be better in the snow than the OEM tires were. We get a lot of snow up here in the winter so it's a safety issue too.
Russ
Old 07-03-2019, 07:49 AM   #20
My thought is that the new tires on the new truck, are adequate for the load rating of the truck. Run them till they wear out, then do a little research, and balance that against how the old ones performed for you, and you should easily arrive at a tire that will work for you. While I'm sure the truck manufacturers use as cheap of a tire as they can new, I don't think the tire issue is the same as with the trailer manufacturers. Different liability, and warranty laws would be my thought.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
switch, tire, tires
