Old 02-22-2011, 06:29 PM   #11
old guys's Avatar
We tow with an equalizer 4 point hitch and couldn't be happier. After some initial re-adjustments by our dealer on the rear bar mounts it towed even better. You are correct that the vfks has a quite heavy tongue weight so get a hitch that is heavy enough. Fine tuning to get the trailer sitting level for the load you are carrying is actually fairly simple to do yourself. Old Guys
Best loved friend ever!!! (greatly missed)
old guys is offline   Reply With Quote
Old 02-23-2011, 01:57 PM   #12
great white's Avatar
Don't have a V-lite, but I haul a 2011 831RLBSS with this:
Featured Product: Center Line
www.huskytow.com/FTP/PDF/P01045_HTCH_CenterLinePDF.pdf
No Complaints when towing.
However, it is subject to some of the limitations on a standard "equilizer" style hitch.
IE: You need to be inline with the trailer in order to remove the weight bars, etc....but you don't need to disconnect them to reverse.
I usually line up the trailer, remove the bars and then back it in to the spot.
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
