Old 11-24-2013, 04:23 AM   #1
golfmedik's Avatar
Viair Air System Install on a 6.7L Ford
Some of you know that I installed a Viair 10007 system on my 6.4L F350, but I just did the install on my '13 F350. It WASN'T easy by any means as the trucks are TOTALLY different underneath, while looking very similar from the outside. I did it with out drilling a single hole in the frame by using a bolt on bracket that I rigged up for the '10. The tank would not "hang" like it did on the 6.4 due to clearance issues, so it now 'sits' under the truck. Here are a few pics.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 11-24-2013, 05:56 AM   #2
Nice job! I don't have pics of my install, but I installed a VIAIR system on my 6.7 about a year ago. I made my own brackets also and mounted it under the passenger side. The air intake is inside the door post and sucks in clean dry passenger compartment air. It's a great system and airs up my camper tires which are supposed to be 110 PSI. My home air compressor didn't seem to have the guts.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
