Old 03-12-2013, 10:54 AM   #1
golfmedik's Avatar
Viair System installed
I thought I would post a couple of pics of my Viair 10007 install. Made up an ingenious bracket that I found on another forum. It is made out of 1" thick walled Square tubing and 1" wide cap steel with 10"x1/2" bolts with locking nuts.
Did the install under the right side of my dually. Anyone with Fords from '99 on can put them here, but may interfere if you put electric AMP steps on.
I mounted the tank on the bracket that I made. Then put the tank into place and tightened. I then put the compressor behind the tank on a Viair compressor bracket bolted to the frame with grade 8 bolts(a little overkill but!).
I ran the compressor breather tube up into the grommet on the lower right rear of the cab. Took a hole punch and punched a hole in the grommet and fed the tubing through, put on the filter and curled it up behind back seat(always gets good air). Then wired it all up and put an air chuck under the right side of the truck. I went back and put a 90* cut off in place to stop the leaking.
Once wired up to the upfitter switches, I piped all of the tubing through the flex boot under the dash and up through a Dual Firestone Pneumatic Guage so I can inflate each one independently. Love having air bags that I adjust on the fly.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 03-12-2013, 10:59 AM   #2
golfmedik's Avatar
I then thought about how to keep the air connection free from debris. This is what I came up with.
Make sure to put a coat of lithium grease in the rubber cap to help you get it on and off. This system has been on the truck for about 9 months or so now. It has a 100% duty cycle compressor so I can air up tires, floats or whatever I need air for. I love it.
Old 03-12-2013, 11:02 AM   #3
Fulltime family RVer
I'll admit, I'm a little jelly. I looked at these and couldn't justify the cost for me. But, man oh day, what a nice setup!
Old 03-12-2013, 11:10 AM   #4
Jay Pat's Avatar
Nice install.
Pat
Jay Pat is offline   Reply With Quote
Old 03-17-2013, 04:28 PM   #5
jevanb's Avatar
this is the box I mounted my compressor in
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 03-17-2013, 04:42 PM   #6
golfmedik's Avatar
Nice. Out of the elements!
Old 03-17-2013, 05:28 PM   #7
Camper Less Camping
Cajun Po-Boy's Avatar
Nice setup!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 03-17-2013, 07:47 PM   #8
PHS79's Avatar
Very nice! My Airlift QuickShot system is one of the best mods that I have done to my truck. Not only for use with the bags but the system gets used at least 2-3 times every camping trip for filling bike tires or toys for the kids.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 03-17-2013, 08:00 PM   #9
John McClain's Avatar
very nice
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
