Equal-I-zer 600 would barely be enough capacity for you. I would be concerned about being to close to the TW limit, and getting bouncing ("porpoising"). Equalizer does not make an 800 lbs unit. I do like my Equal-I-zer, and would recommend you call their excellent technical service line, and ask them if the 1000 lbs unit would be too stiff for you.
If not, you should find some other 800 lbs kit that includes integrated sway control. Blue Ox might have that size. I'm pretty sure the Reese Dual-Cam system does as well. Those 3 are the tops around here, as far as bang-for-the-buck, and having been around for some time.
