Old 04-08-2019, 07:59 AM   #1
Visit to CAT Scales
Equipment
Truck - 2018 F250 XLT CCSB 6.2 Max Pay load 3,275
Trailer - 2018 Rockwood 2906 dry weight of 7,300 Ready to do 8,020
CAT #'s
Truck Steer Axle Drive Axle Trailer Axle
4,200 3,480 Combined 7,680
No Weignt Dist. 3,700 5,260 6,740 Combined 15,700
With W/D 3,900 4,980 6,820 Combined 15,700
If I'm doing it correct I show 1,280 Tongue weight
Do you Think I have any twinking to do.
Thank you!!
Egghead is offline   Reply With Quote
Old 04-08-2019, 09:46 AM   #2
clarkbre's Avatar
Your tongue weight will come from the No WD truck weight minus the first truck weight GVW. In your case:
(3700+5260) - (4200+3480) = Tongue weight
8960 - 7680 = 1280
As far as % of tongue weight for your trailer:
1280 + 6740 = 8020
1280/8020 = 15.96% tongue weight.
The tongue weight may be a little on the heavy side but it's nothing that would be worrisome. If you do want to lighten the tongue a little, move some of the gear out of the front of the trailer and put it at or just behind the axles on the trailer.
As far as your front axle, you may want to tension the WD bars a bit more. That will force more weight transfer to the front and get your truck closer to it's stock, front axle weight.
How does it tow in it's current state?
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 04-08-2019, 10:12 AM   #3
Thank you Clarkbre,
It pulled really good, 30 miles each way to CAT scales and back. It was not windy and believe it or not, not one Semi passed me on trip there or the trip back so not sure how push and pull is for passing trucks yet. I,m using the Fastway E2 hitch so maybe I should add a washer to help get more weight pushed up front. My truck front unhooked was 41"- W/O W/D rased it to 41 3/4"
W/WD brought it back down to 411/4".
Thank you!!
Old 04-08-2019, 01:47 PM   #4
I don'[t think you have any "TWINKING" to do
Nor do I think you have any tweaking to do either, unless you decide to see if you can add more weight back to the front axle. But, seeing as you're within 1/4 inch of truck only height, with WD engaged, I suspect any additional twinks or tweaks will put you past the 41" truck only height.
If it handles nicely, I'd tow as is, for now and adjust later if need be.
Mike
TV = 2017 Ram 3500 (aka FRAM)
5er = SOB (2019 Grand Design Reflection 367BHS)
walaby is offline   Reply With Quote
Old 04-09-2019, 02:30 PM   #5
sfsgm's Avatar
Originally Posted by Egghead View Post
Equipment
CAT #'s
Thank you!!
You might want to look up that word and consider changing it!
2016 Nike Take Down Wrestling Shoes
42 ft square Dollamur high school wrestling mat
sfsgm is offline   Reply With Quote
Old 04-15-2019, 08:34 AM   #6
Clark - Thank you for your reply. I have the same truck and a very similar trailer, with almost the exact same measurements. Your comment about moving weight forward made me understand how the scales can help me fine tune my setup. I have read a zillion posts on scales and this one finally got through! lol! Thanks!
t.simpson is offline   Reply With Quote
Old 04-15-2019, 09:31 AM   #7
clarkbre's Avatar
Glad it helped. I just sent you a PM with a spreadsheet to help look into where your weight is on each axle.
cat, scales
