Old 04-14-2010, 12:46 AM   #11
Here is my guess about your tires, Trail Express appears to be a trade name. Voma is or was an importer of auto parts and accessories and they did import at least one container of tires from China in 2008. There are several complaints about the tires on forums for recreational vehicles. Voma was/is a very small company with sales in 2009 of less than a $1,000,000.
I suggest you use caution with your tires. Get an opinion on the tires if you know someone you can trust, or if you can afford it, switch to a known brand. Tires are one of the important parts of a trailer. I would talk to your dealer as well. He knows the tires are El Cheap o's and maybe he will be a good merchant. But keep in mind he put a customer into those tires to begin with. Not a friendly thing to do.
As far as the gas filed tires. They help a little. Do not go out of your way to use the gas.
Big Bird
Big bird is offline   Reply With Quote
Old 04-14-2010, 07:14 AM   #12
Herk7769's Avatar
Air is 78% nitrogen already.
78% Nitrogen; 21% Oxygen and 1% other gasses. Oxygen is not that much "smaller" than Nitrogen. The "Other gasses" include a LOT of small stuff like Argon, helium and Hydrogen, but even if all that leaked out through the rubber it would change the pressure but only a psi or two. If you have a leaker it will be either tire age, the rim seal, or the stem seal.
My vote is for regular Air.
Space shuttle tires? Wonder if the reason has to do with the Oxygen and fires...
Coefficient of expansion...?
Hmmm.
Need to look that one up.
HAM CALLSIGN - KC3FFW
Old 04-15-2010, 06:55 PM   #13
Again guys, thanks for all the input. Hopefully, if the company is that small, maybe the new ones they are sending won't be the same brand. Windrider, if I ask for advice, and get offended, it's bad on me, not on the person kind enough to respond. Cheers!
WillyB is offline   Reply With Quote
Old 04-16-2010, 07:44 AM   #14
Herk7769's Avatar
Windrider's comment about "dryness" and uniformity of composition makes a lot of sense for critical applications. Perhaps where a variance of 1 or 2 PSI might cause issues. How a tire that differs by a PSI or 2 might cause that much of an issue on a passenger car or trailer is beyond me.
Old 04-28-2010, 08:54 PM   #15
old guys's Avatar
tire problems
We also have a weather checking? problem on our 5 mo. old v-lite and our dealer has been excellant about replacing them. Unfortunately they are unable to even get more trail express from the suppliers so we will go with whatever they get and see how they work out. That's what tire warranty is all about. Maybe it is better that they can't get the trail express from the responses on here. Whatever.....life goes on one day at a time and we will handle it daily. Good luck with yours. Old Guys
Best loved friend ever!!! (greatly missed)
old guys is offline   Reply With Quote
Old 04-28-2010, 09:50 PM   #16
shineysideup's Avatar
Hmmm.
I gotta agree, nitrogen is a waste (if you have to pay for it). There is an added benefit that nitrogen is not flammable and will not add oxygen to a fire on an airplane, drag car etc. from the tires.
From consumer reports;
October 4, 2007
Tires - Nitrogen air loss study
Filling tires with nitrogen rather than air is becoming a common practice in the replacement tire market. This service offers tire dealers another avenue for making money while also promoting safety. The claimed safety benefits often include the potential for reducing air loss compared to an air-filled tire. Maintaining proper inflation can help prevent tire overheating; promote optimum tread life; and reduce rubber aging and wheel corrosion. The use of nitrogen in large truck fleets and the commercial tire industry are well documented and support these claims.
The National Highway Traffic Safety Administration (NHTSA) has seen reduced aging of tires filled with nitrogen. Though the data does support that passenger car tires could benefit by all the claims made for nitrogen, tire manufacturers say that they already design tires to perform well with air inflation. And while nitrogen will do no harm, manufacturers say that they don't see the need to use nitrogen, which generally adds $5 or more per tire charge.
Consumer Reports wanted to find out if nitrogen is worth the price, so we purchased a Nitrogen Inflation System and checked out how well the inflation held up over a one year period. We evaluated pairs of 31 tire models of H- and V-speed rated, all-season tires used in our tread wear test from 2006. We filled one tire per model with air and the other with nitrogen. The test was quite simple: fill and set the inflation pressure at room temperature to 30 psi (pounds per square inch); set the tire outdoors for one year; and then recheck the inflation pressure at room temperature after a one year period.
The tires were filled and deflated three times with nitrogen to purge the air out of the tire cavity. (DOES COSTCO AND SUCH DO THIS?) We also used an oxygen analyzer to be sure we had 95-percent nitrogen purity in the tire--the claimed purity limit of our nitrogen system, which generates nitrogen gas from ambient air.
The test started on September 20, 2006 and the final measurements were taken on September 20, 2007. The results show nitrogen does reduce pressure loss over time, but the reduction is only a 1.3 psi difference from air-filled tires. The average loss of air-filled tires was just 3.5 psi from the initial 30 pressure setting. Nitrogen-filled tires lost an average of 2.2 psi from the initial 30 psi setting. More important, all tires lost air pressure regardless of the inflation medium, so consumers should check their tires' air pressure routinely. No evaluation was done to assess the aging claim.
Bottom line: Overall, consumers can use nitrogen and might enjoy the slight improvement in air retention provided, but it's not a substitute for regular inflation checks.
author--Gene Petersen
shineysideup is offline   Reply With Quote
Old 09-17-2013, 07:56 PM   #17
Commercial Member
Originally Posted by milzat View Post
Name: Voma Tire Corp.
Phone: (901) 672-0816
Address: 5815 E Shelby Dr
Memphis, TN 38141-6804
I believe that might be the importer.
If someone posts the DOT serial I can tell you the plant that made the tires. This information has been previously posted on my blog.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
