08-06-2015, 05:56 PM
Walmart Oil changes
I just had the oil changed in my Jeep toad. I watched them and they don't pull the drain plug any more! They use a pump to pump it from the dipstick hole.
That does not drain all the impurities. I guess I'll be changing my own oil from here on out! No wonder they want you to change your oil every 3,000 miles. I use Mobil 1 synthetic so I go until the jeep says to change.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
08-06-2015, 06:10 PM
Oil change at Wal Mart? Hell you can't even buy ammo from a Wal-Mart in Los Angeles county.
08-06-2015, 06:27 PM
And your point is?
08-06-2015, 06:34 PM
A lot of oil change places have started to do this, liability over leaking or cross threaded drain plugs.
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring, Blue Ox baseplate W/Ready Brute Hercules tow bar and Ready brakes
08-06-2015, 06:35 PM
That's the way they change the oil on an inboard motor on a boat and that motor is a car motor with some added parts for cooling.
Think about things before you do them make life easier not harder.
08-06-2015, 06:55 PM
Inboard is done that way out of necessity To hard to get under motor to access plug.
I will stick to old school The best suction available will not get the crud off the drain plug magnet of lying in the bottom of the oil pan.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-06-2015, 07:06 PM
X2. As far as leaking or cross threaded oil pan plugs, I use a Kwik Kar place for my oil changes and they let the vehicle idle for 5 minutes after changing oil before releasing it to make sure there are no leaks.
No problems yet.
08-06-2015, 07:07 PM
Originally Posted by B47
And your point is?
Did not know they even changed oil. Cheer up go RVing.
08-07-2015, 07:34 PM
Kwik Kar robbed me last time there... so it will definitely be... the last time there. Charged me $84- for a fuel filter I can buy at NAPA for $11.95. Told me they had both fuel filters and had only one of them... but charged me labor for both. Went back to speak to the manager, twice, and he was conveniently never around.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
08-07-2015, 08:02 PM
Get one of these....
Fumoto USA | Quick and Easy Engine Oil Drain Valves
Had one on my Hummer H3 for about four years, and never had a problem or a leak. Of course the drain was above a 1/4 in steel shield, but it sure made draining oil easy as heck. Might put one on my Silverado...
Probably not a Walmart problem; a California problem.
08-07-2015, 08:05 PM
Everyone of our aerial lift trucks at work had one of these ( 780 units) worked great!!
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
08-07-2015, 08:17 PM
F5. I said Los Angeles County not California. There are lot's of places to purchase ammo/Firearms ect in Los Angeles County just not Walmart. Pay attention.
And there is no way in hell i would have Wally World change my oil.
08-08-2015, 06:45 AM
YOU PAY ATTENTION!!!
"Los Angeles County, also known as L.A. County, officially the County of Los Angeles, is a county in the U.S. state of California."
From your info under your avatar...
SOCAL - disambiguation for Southern California.
So, it is pretty easy to believe you live in California and LA county is in California so yes, I paid attention.
And as you attempted to do, I tried to add a little humor to the subject. I guess we both failed.
And sorry it hurts to mention that you live in CA. I can totally understand that.
SO CHILL!!!!!!!!!!!!!!!!!!!
And I wouldn't have them change my oil either!
Have a nice day...................
08-08-2015, 07:03 AM
Let's not escalate an argument over something of little importance. Let it go.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
08-08-2015, 07:10 AM
Tried to get an oil change at Walmart recently and they reported they couldn't get the filter off. Went 2 blocks down to time-it-lube and they had no problem.
2018 Forester 3011 DS
08-08-2015, 08:30 AM
The fact that every Walmart in the country. Has a bunch of young kids working at them. It's fine but they don't really give any extra effort either this may be why they couldn't get your filter off. Went to ours once for an oil change took over an hour. Won't do that again. But they did pull the plug and drain it. Just my two cents
Sent from my iPhone using Forest River Forums 2015 21ss havein fun
08-08-2015, 10:35 AM
Deleted.
08-08-2015, 05:06 PM
Walmart Oil changes
Walmart loosened it for them. Lol
08-09-2015, 07:16 PM
Up here in the GREAT white north, Walmart gave up their lub depts and now have a Mr Lube at them. Mr Lube is owned by the same guy who owns Boston Pizza, Mr Jim Treliving.
2014 Forester 3051s
2012 Sonic toad
08-10-2015, 10:48 AM
Friday took my Ram into dealership (Parks Motors) for a oil change. When I got home could smell burning oil. Opened the hood and they spilled oil all over the left side of engine. Looked underneath and oil was still dripping off the frame...
