Old 02-05-2011, 11:00 AM   #11
lbtex's Avatar
One of the good things about the Titan Tow package is the inclusion of the transmission temperature. Dan is exactly right, you will need to run in fourth a lot but in even terrain and small rolling hills I do use overdrive but keep an eye on the temperature. On longer climbs the temperature will also climb so I pull it down to fourth. Your trailer is a bit heavier than mine so use the guage to figure out what works with your rig.
2009 Rockwood 2607
2007 Nissan Titan
lbtex is offline   Reply With Quote
Old 02-05-2011, 09:56 PM   #12
baldy's Avatar
Have any of you had reared issues. I was looking at the Titan before my F150 and I read that the rearends were breaking and then they put the diff covers on with the heat sinks and synthetic fluid. Just curious?
baldy is offline   Reply With Quote
Old 02-06-2011, 06:30 PM   #13
Better check your weights. Stop off at a CAT scale. Think you might be overloaded..
Good luck
wayne1 is offline   Reply With Quote
Old 03-09-2011, 08:42 PM   #14
Stumbled onto this one a bit late, hopefully not too late. I pull an 831bhss with a '08 Titan CC Pro4X short bed. The powertrain is, in my opinion, one of the most under rated in its class. It pulls like a mule. Peak torque @ around 3600 rpms. She'll drop down one, lock up and away you go without it screaming at 4500 rpm's. BUT....You'll need a 1200/12000 equalizer or dual cam to keep it on the road. Dial it in right and you'll be fine. I added ride rites also (I carry a lot of gear). Just about maxed out on the rear axle also. You should be ok.
WBFD is offline   Reply With Quote
