Old 06-03-2016, 03:31 PM   #21
thebrakeman's Avatar
Originally Posted by Underthedog View Post
If you wind up opting for a WDH, Reese makes a single bar light duty WDH that we used for many years on a pup (~3500 max), along with the reese friction bar anti-sway. I wish I could have carried it forward onto our current pup.
Yep, "Reese 400 Single Bar". We used that (and a friction sway controller) with our 3000 lbs Coleman popup for 7 years (~375lbs TW). Worked great. If you have less than 350 lbs actual TW, the Reese mini-350 is also a good choice, having integrated sway control.
thebrakeman is offline   Reply With Quote
Old 06-05-2016, 10:27 PM   #22
I looked a little closer and found the frame under the camper is boxed but the "A" frame is c channel. I'm guessing that is the weak spot Palomino thinks will buckle under a WDH. I have my first trip coming up this week and we'll see how it tows. Maybe it falls right in line and all my concerns are pointless.
Finnian is offline   Reply With Quote
palomino, sway
