Old 11-17-2012, 03:02 PM   #1
daydreaming about camping
jeeplj8's Avatar
WD conundrum - back of truck sitting higher?
I am working to adjust the Reece dual cam trunnion bar 12K WD kit. Going simply off measurments to bottom of front and rear of truck, in order to get the front back to level (same height loaded and unloaded) I am tilting the head almost to the full 15 degrees. This raises the rear of the tuck 2 inches. Yes, the hitched height of the truck and therefore the coupler, is 2 inches HIGHER than unhooked.
Um - how does that work, and what should I do?
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 11-17-2012, 03:12 PM   #2
Dave_Monica's Avatar
Go back to the point where the adjustment had no further effect on the front ride height and try it there.
Dave
Old 11-18-2012, 09:10 AM   #3
MtnGuy's Avatar
What are you using as the reference point ??
You can not use the bumpers as the reference points. You have to use a body reference point in line with the wheel axis....albeit the top of the fenders.....and the exact same spot every time.
The bumpers will give you all sorts of weird measurements.
Old 11-18-2012, 10:16 AM   #4
Wanna Be Camper
SaskCampers's Avatar
Sounds like you may need to buy a longer drop shank to get the head at a level starting point then start your adjustment from there. I had a heck of a time when we had our Dodge trying to get a drop shank that was long enough and eventuayyly welded an extension to the bottom and drilled a new hole in the 11" drop shank I had to get the trailer level. It was well worth it as all my sway issues went away when the hitch was set to work the way Blue Ox designed it to..
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 11-20-2012, 11:30 PM   #5
jeeplj8's Avatar
Just posted my scale numbers. Got it set close to level. Thinking about one more indent on the head, lost 120 pounds of front axle from unloaded weight.
Noticed a huge difference pulling with this system.
Old 11-21-2012, 06:03 AM   #6
Commercial Member
huntr70's Avatar
If you do have the F350 suspension as listed in your signature, it may actually be tough to get the Excursion leveled out.
Did you also change the front suspension, or just the rear springs?
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 11-21-2012, 08:26 AM   #7
MtnGuy's Avatar
jeeplj8, do have a self leveling system on the Excursion ??
Old 11-21-2012, 09:08 AM   #8
jeeplj8's Avatar
I put the one ton springs on front and rear. Does not have an auto leveling suspension. Looks very level, and drives much better than before. We are here until Sunday, I may dial in one more detent on the hitch head.
Old 11-21-2012, 10:03 AM   #9
Missing Link
cyclepuck's Avatar
Did you try taking some of the tilt out of the head.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 11-21-2012, 11:49 AM   #10
Missing Link
cyclepuck's Avatar
Read it wrong the first time. What does Ford suggest in manual as far as set up. On my Chevy they allow a 1/2" rise in front.
2014 Puma 30-DBSS
