Old 06-17-2016, 09:04 AM   #1
WD hitch needed?
Sure this gets asked a lot but I'm having trouble deciding if I need WD hitch or not. I've towed heavy offroad vehicles and excavators with this truck and never even thought about getting one but many people say that TT catch so much wind that you need one. I bought the new camper from RVW so I won't have it for at least a week so I can't test anything out until right before a big trip I have planned the week of 4th of July. If you think a WD is needed what would you recommend? Trying to stay cheap and simple since I'm spending so much $$ right now.
TT info
GVWR 6,900 lbs
Dry Weight 4,334 lbs
Hitch Weight 530 lbs
Length 25' 7"
Dodge RAM 2500 Quad Cab Tow Ratings has tow package with class IV hitch
5.7L HEMI
4x4 Short Bed Curb Wt 6,072 Tow Wt 8,850 GCWR 15,000
Payload 2730
dan4jeepin is offline   Reply With Quote
Old 06-17-2016, 09:11 AM   #2
Wobbles's Avatar
I would say yes you do but others might not.
Your state may have laws that require it when the trailer is over a certain weight.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 06-17-2016, 09:20 AM   #3
Sham183
mopwr4me2003's Avatar
I would just for safety reasons. You never know what could happen. The extra $500-700 could save you from a accident and possibly costing you a truck, TT, and injury. Most people on here seem to like the 4 point equalizer hitch but there are so many to choose from just do your research. Dealers will sell you one and set it up for you but will cost you a little more $. Good luck!
mopwr4me2003 is offline   Reply With Quote
Old 06-17-2016, 09:27 AM   #4
SeaDog's Avatar
I also haul heavy loads without a WDH, the reason I have the WDH on my TT is so that the trailer travels level so less wear and tare on tires and such. Your 2500 will have no problem either way. Most WDH do have a sway option I have never installed mine just load correctly
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-17-2016, 09:51 AM   #5
Canadian Member
Those with a 3/4 ton truck can probably answer your question better than I can, but if the actual loaded hitch weight is only 530#, you could probably get away with not needing the weight distribution. However, I'd still suggest you should have sway control for a trailer that size so you may end up getting the WDH anyway.
2019 Rockwood Signature 8290BS
Old 06-17-2016, 10:00 AM   #6
For trucks that have beefy rear springs (3/4 and up), the primary reason for a WD is to get weight back on the front... which gets removed anytime you put weight behind the rear axle.
500 lbs tongue weight may not matter.
For my F250 that is normally level, I would be sagging without a WD. (Of course my TT is 11k lbs too.)
For modern 2500's that have their rear ends jacked up, a little sag won't hurt. In these cases, WD is for front end and anti-sway.
Lots of love for WD with built-in sway on the forums. Not many use the separate sway bars... however, the sway bars have much more control than the WD themselves. I use both.
325BH is offline   Reply With Quote
Old 06-18-2016, 11:24 PM   #7
mrpep's Avatar
TT info
GVWR 6,900 lbs
Length 25' 7"
5.7L HEMI
Payload 2730
Ive read that anything over 4000 should have a wdh.
mrpep is offline   Reply With Quote
Old 06-19-2016, 08:29 AM   #8
SeaDog's Avatar
Who ever wrote what you read needs to go back and rethink their statement. My F350 @ 7100 lbs does not need a WDH pulling 4K lbs of trailer. with that said if the tow vehicle was very light it might.
We pull heavy trailers around here all the time without WDHs.
Retired Navy
Old 06-19-2016, 08:42 AM   #9
If your buying from "RVW" they have the best$ on Hitches! Even though your unit is ONLY 26' long you Need Sway Control,this is a "BEFORE NEEDED" item Not After! RVW sells LOTS of "Equilizer Hitchs with Built In SC" buy one while there ! Youroo!!
Old 06-19-2016, 09:00 AM   #10
Rhody's Avatar
TT info
GVWR 6,900 lbs
Length 25' 7"
5.7L HEMI
Payload 2730
HUSKY CENTERLINE
Rhody is offline   Reply With Quote
hitch
