Old 09-16-2010, 06:36 PM   #1
Question WD Hitch Setup Question
I'm curious as to what I should do when I set up the hitch on my new truck next spring. Have you folks had your TV & TT empty or loaded during the setup procedure?
When I setup the hitch this year on my truck, both were empty. I noticed on the trip to Indy that the rear of my truck was lower. I had more gear than normal in the box including my generator.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 09-16-2010, 06:54 PM   #2
Hipshot's Avatar
When I picked up the TT in Elkhart both the TV and TT were empty. I set up the hitch IAW the manual. Before our first camping trip I adjusted the hitch with the TV and TT loaded for camping. In my case this involved turning the shank around and adding more washers. Adjusting the hitch yourself is not difficult. If you have any problems call the Progress number in the installation manual or post on this forum.
2010 Rockwood 2604SS
2008 Silverado 1500 LTZ 4X4
Great Wife and Idiot Yorkie
True Friends are like diamonds, precious and rare.
False ones like autumn leaves found everywhere
Hipshot is offline   Reply With Quote
Old 09-17-2010, 09:12 PM   #3
milzat's Avatar
Both TV & TT were loaded.
So was I.
milzat is offline   Reply With Quote
Old 09-17-2010, 10:11 PM   #4
BigDTx's Avatar
What type of Hitch?
We have the Equilizer 4 way sway control 1000/10000LB and I set it up with both trailer and truck empty then aftet I towed loaded the first time I adjusted the setup. The back of the truck sat lower with both loaded
BigDTx is offline   Reply With Quote
Old 09-17-2010, 10:50 PM   #5
It's the Husky bent bar type hitch.
Old 09-17-2010, 11:03 PM   #6
So was I.
Your wife must be a saint. She been puttin up with you long?
MightyMike is offline   Reply With Quote
Old 09-18-2010, 06:00 AM   #7
milzat's Avatar
37 years....................
Old 09-18-2010, 09:50 AM   #8
Hemlox's Avatar
It is best to set it up loaded, otherwise you will have to adjust it once you are loaded up for camping. The extra weight is going to make a difference on how the hitch is set up. Hope this helps.
2006 Rockwood 8318SS
Hemlox is offline   Reply With Quote
Old 09-18-2010, 01:51 PM   #9
Thanks guys, when I set up the hitch back in the spring I didn't really have my RVing "kit" put together. Now after a few trips I know what I usually have in the truck & trailer. When I set up the hitch for the new truck next spring, I'll load up as if I was heading on a trip.
The hitch instructions explain how to make your adjustments, but make no mention of doing it unloaded or loaded.
