Old 06-28-2018, 03:53 PM   #1
Question WD Hitch Shank Length
Hi All,
I tow a small 2109 Rockwood behind my 2017 Grand Cherokee. I already cut off a short vertical portion of the shank that was rubbing on the ground when I went into some elevated driveways, but I am also wondering about what appears to me to be the extremely long portion of the shank that goes into my car's receiver. Besides adding extra weight, it also seems like it's length would cause unusual stress. Is there some reason I can't shorten it? Is there an "optimal" distance for the "ball" to be from the back of the tow vehicle. Most of the WDHs I've seen seem to have this long shank. They certainly add extra weight!
2017 Rockwood 2109S
2017 Jeep Grand Cherokee "Hemi"
jrl95608 is offline   Reply With Quote
Old 06-28-2018, 04:49 PM   #2
I’m not the expert on this, but I believe the extra length on the shank is part of how it does the weight distribution. I wouldn’t remove any of that part..
Although I could be wrong.
Sent from my iPad using Tapatalk
2019 Flagstaff V-Lite 30WFKSV
2021 Chevy Silverado 3500 HD DRW High Country
ImTravis is offline   Reply With Quote
Old 06-28-2018, 05:35 PM   #3
This is what I'm trying to find out. I have just seen a hitch site that apparently sells shanks of different lengths.
2017 Rockwood 2109S
Old 06-28-2018, 05:36 PM   #4
007matman's Avatar
Generally speaking you don't want it dragging on the ground and want as short of a shank as possible.
I'm surprised that it's dragging though, typically the shanks are short from the manufacturer.
Can you upload a pic of your setup?
Sent from my Pixel 2 XL using Tapatalk
007matman is offline   Reply With Quote
Old 06-28-2018, 05:43 PM   #5
I have one of the adjustable ones that you can turn up or down. The Ball height is better when it points down then when it points up, but it was too long pointing down, so I had about 2" cut off and it works fine now. I also think the shank going into the receiver should be short, but most of the WD hitches seem to have long shanks; and they don't go any deeper into the receiver, just keep the ball further from the tow vehicle.
2017 Rockwood 2109S
Old 06-28-2018, 06:10 PM   #6
Shorter is better for the shank length. I’ve drilled a new hole in my Equalizer shank, the ball is now 2 inches closer to the TV.
Dustyhd is offline   Reply With Quote
Old 06-29-2018, 07:47 AM   #7
007matman's Avatar
You can drill another hole and get it closer (which may require you to cut off some length as well) or, you could just purchase another shank.
Amazon is a great resource.. I've bought several from them.
Old 06-29-2018, 10:44 AM   #8
MillMitch's Avatar
I emailed the question to Fastway (Equalizer and E2 hitches) and got this answer in case anyone was curious. Pretty much the answer I expected.
Jun 29 at 9:46 AM
Mitch,
Thanks for the email. That’s a good question. Sometimes people do like the shank to be shorter, but this is something we don’t recommend doing, as we have not tested the hitch with any type of modified shank. Would it work? Probably, but I’m not sure. But it would definitely void any type of warranty claim the customer may have down the road, as our warranty policy would not cover a hitch that has been altered or modified beyond the recommended adjustments.
Thanks,
Jacen Condie
Customer Service Representative
Office 800-478-5578
Sent: Friday, June 29, 2018 7:39 AM
To: Fastway Support <fastwaysupport@progressmfg.com>
Subject: Re: RE: RE: question about E2 hitch
Hi guys,
I belong to the Forest River Forums and was reading a discussion regarding shank length (not the rise or drop) on WDH's. Members are obviously talking about their own hitches, but one of the comments was from an Equalizer owner. Intuitively it makes sense to me that the closer the hitch ball is to the tow vehicle, the less stress on the tow vehicle receiver. However, I'm not an engineer and wanted to check with you. I have an E2 hitch and am towing with a Durango - any reason I can't shorten the shank?
thanks,
Mitch
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 06-29-2018, 10:56 AM   #9
I believe this discussion has split into two separate issues:
1. Shortening the actual length of the shank by cutting off some portion of the end that inserts into the receiver.
2. Shortening the distance from the receiver to the ball by drilling a new pin hole closer to the ball (i.e., shortening the "working length" of the shank.) BTW: If you did this, you could also do #1, as more shank would now extend past the receiver.
With respect to #1, any portion of the shank that extends outside of the square receiver (in "front" of the receiver) could be cut off to lighten the shank. Only the portion of the shank inside the receiver is doing any "work." However, I would not be surprised if the factory would void your warranty.
With respect to #2, I would agree with the factory, in that they would probably void your warranty as you have changed the assumed distance from the ball to the TV, although I would expect their real concern would be if you lengthened the working length of the shank (say, to allow you to fully open your tailgate).
2011 Traverse LT, 3.6L, FWD
Old 06-29-2018, 11:11 AM   #10
I am in This Camp! Youroo!!
Old 06-29-2018, 11:34 AM   #11
007matman's Avatar
They are just trying to avoid legal issues that could stem from improper modifications.
I had to purchase a extended shank because the one they included in the kit wasn't long enough. They do warn users to not purchase longer ones than what is required.
Old 06-29-2018, 12:46 PM   #12
They told me it was fine to drill a new hole.
Old 06-29-2018, 01:01 PM   #13
I'm assuming you told them you wanted it shorter. Wonder what the response would have been to make it longer?
Old 06-29-2018, 01:04 PM   #14
MillMitch's Avatar
I'll have to take another look underneath, but i think my shank would hit the spare tire without cutting the back end of the shank off after drilling a new hole. Did you use a drill press to drill the hole? or have it done at a machine shop?
Mitch in MN
Old 06-29-2018, 02:34 PM   #15
[QUOTE=jrl95608;1854627]Hi All,
Most WD hitches I've seen the shank can be turned over.
ard58 is offline   Reply With Quote
Old 06-29-2018, 04:06 PM   #16
I used a drill press at my work.
Old 06-30-2018, 10:55 AM   #17
Can it be too long or go in too far?
I did the same thing. A good drill press helps. Start with a .250 pilot hole prior to drilling the final size.
Good luck
pdqparalegal1 is offline   Reply With Quote
Old 06-30-2018, 05:25 PM   #18
I would like to have mine shorter. However if it was moved a 1/2" I could not open my tailgate.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
hitch
