Old 05-29-2016, 07:08 PM   #11
Originally Posted by wrvond View Post
Changing the tilt of the ball affects the angle of the torsion bars. When properly adjusted the bars should be fairly parallel to the tongue. If the ball is upright, your bars may end up pointing upwards with only one link at the hooks, and may not be able to even generate enough torque to shift any weight. If it's angle back too far, your bars will point downward requiring more links in order to shift the weight. The problem here is, any flexing at the ball (dip in the road, etc.) will result in too much torque and could bend bars or break something.
With the Blue ox you cannot adjust ball angle. The bars used are spring steel so they are always bent when setup properly no chance of bending them out of shape. I guess you COULD break something.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 05-29-2016, 07:09 PM   #12
Kenny kustom's Avatar
I could on the blue ox sway pro that I had...
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 05-29-2016, 07:12 PM   #13
2016 Sabre 36QBOK
They don't make the adjustable head any more. You are right there is a chance it's adjustable.
Hensley Arrow
Old 05-29-2016, 07:19 PM   #14
Must have just changed.
Mine was bought in 2014.
2016 Sabre 36QBOK
Old 05-29-2016, 08:29 PM   #15
jimmymjr's Avatar
I loaded up the TT and started adjusting the hitch. I started by leveling the TT and measuring the hight. I set the hitch hight to the same measurements. Coupled the TT the TV. After a few different adjustments It drops 1/4 in the front and 1 3/4 in the back so no change. I got rained out before I could drive it around so I'll give it a test pull and see how it does. It always pulled it good before the front suspension modification so I don't expect much change.
I appreciate all the post it helped. Thanks.
[SIGPIC]Jimmy Miller
2016 27RKSS
jimmymjr is offline   Reply With Quote
Old 06-01-2016, 08:54 PM   #16
jimmymjr's Avatar
Pulled it just over 300 miles pulled fine. I guess the 1 3/4 drop isn't going to affect it much. Again thanks for all the post. I learned a lot. I'll be adding air bags soon. But until then I'm on a month long trip. I'll deal with the other stuff when I get home.
2016 27RKSS
