06-17-2013, 08:42 PM
WDH advice needed!
I recently bought a horse trailer and I am having difficulty deciding what WDH setup to go with.
Ease of hookup/disconnect is important to me as I'm a 5' tall, 105lb girl who just doesn't have a lot of weight/height to put behind manipulating a hitch.
Must be able to back up with it on, as we do a lot of backing in close quarters at horse shows.
My tow vehicle is a 2007 Jeep Grand Cherokee, 5.7L, factory tow package.
The trailer weighs approx. 2600lbs empty and fully loaded with 2 horses weighs roughly 5000lbs. Because these are horses, I do not have the option to redistribute weight in the trailer-- they go where they go.
Tongue weight is estimated to be ~375lbs. It doesn't change much whether the horses are loaded or not, because their weight sits over the axles and is not loaded forward of the front axle.
I am wondering what weight distribution hitch I should be looking at. I was thinking the equalizer, but I am not sure I can snap in the bars myself and I am worried the brackets will move. I would prefer not to have to weld onto my trailer (all aluminum).
My wheelbase is short, so the best sway control possible within a reasonable (sub $600) price range would be the best. I can technically tow this trailer with this vehicle without the WD, but I really want the sway control. Wondering if maybe just some Timbrens and sway control device would do the same job with a lot less hassle?
I have only ever towed goosenecks, this is my first bumper pull, but I had to downsize with only 1 horse and no need for a giant truck and trailer.
I really appreciate any help.
ETA: the total length on the floor of my trailer is 13'4" and hitch to bumper is 16'6". The max tongue weight for this vehicle is 720lbs.
06-17-2013, 09:05 PM
I have the Husky Centerline hitch. You would have to spend a little more.
It has WD and sway control. You would have to increase your tongue weight a touch (minimum is 500 lbs).
The pluses of this hitch:
Bolts onto your trailer frame (no drilling or frame modification)
You can back up with the hitch (you do not have to remove the bars)
Minuses of the hitch:
You will have to have your tow vehicle lined up fairly straight with your trailer to hook on the WD bars
You need to raise the tongue of the trailer to put the WD bars on easily (power tongue jack is ideal)
Info on the hitch here:
http://www.huskytow.com/wp-includes/...-A_HITCH_1.pdf
Others will chime in with their hitches.
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
06-17-2013, 09:17 PM
Not sure I actually can increase the tongue weight. By design, horse trailers are light in front. The horses (1000lbs each) stand directly over the axles.
I think to get the tongue weight to 500lbs I would have to put about 200lbs of dead weight directly in the nose of the trailer, which would obviously be dangerous to living cargo in an accident.
06-17-2013, 09:25 PM
You could perhaps talk to the tech people at Husky to check about the requirements for the tongue weight if you want to persue further. I was thinking adding something outside the trailer on the front of the frame if there is room (don't want to hurt the horses). Regular trailer carries propane tanks, batteries etc which add well over 100 lbs.
Good luck with the other hitch possibilities. You'll get something suitable that fits your needs!
06-17-2013, 09:30 PM
I have no experience with this hitch. My son recently bought a new TT. The dealer installed a Anderson hitch. It takes a different approach to sway and weight control. I think if I ever buy a new hitch I'll go with it. Do a Google search their also a utube video about the hitch.
Phil
2018 Rockwood A213HW
2012 Nissan Frontier V6 4X4
06-17-2013, 09:33 PM
Horses are large animals. The front legs are normally ahead of the trailer axles which gives you more tongue weight. This is unless you have some compartment up front preventing this. If that is the case, you may need to add dead weight. Too light of tongue weight will cause a dangerous situation. You will want at least 10% of the gross trailer/horse weight on the tongue. If you have a power tongue Jack, the equalizer is very easy to use. I have also seen people have good success with the updated Anderson hitch with built in sway control.
06-17-2013, 09:43 PM
Do not have a power jack. Those are very uncommon on horse trailers.
The design of the trailer is that there is roughly 6' of space in front of where the horse's front feet go, to accomodate the horse's head/neck and also some equipment. However, nothing heavy goes there as it's not safe in case of an accident, everything is secured.
I am guessing the tongue weight is 375ish empty and about 420 fully loaded. This particular model is actually the shorter one that produces more tongue load. These are also available with even more storage space in front and an 18'6 overall length, tongue weight there is about 480 fully loaded despite being at least 600lbs more trailer.
Horse trailers are a little different than TTs-- there is only about 3' from nose to hitch to pop something on there, at best maybe I could put a battery in.
The trailer looks like this, except it is 18" longer between the doors marked and the nose radius begin. The axle position (dual axle) is marked by the yellow bars, and the horse stands between the rear bumper and the front doors--so there really is not much horse in front of the forward axles except for the head/neck.
06-17-2013, 09:45 PM
Engineer of Crazy Train
These are not TT with a lot hanging off the rear to cause a pendulum. Can't follow TT rules on these trailers.
I would go and ask around to other people in the business. I was actually having this discussion with a horse owning friend after I blew by an E150 on a grade who appeared grossly overweight.
Personally, I would go simple with a regular WDH and if needed, a friction sway bar. It doesn't sound like a bunch of tongue weight and a short trailer.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
06-17-2013, 09:53 PM
Been trying to ask around but horse folks are the last to adopt WDH assemblies-- the general answer when asking about this is "buy a 3/4 ton truck so you don't need them"
I do know folks towing very similar apparatus without the WDH and they claim to be pretty happy. Of course, someone who's never had to drive evasively or stop under heavy load will probably be happy.
I may try it without and try the Timbrens. I'm worried I may do more harm than good with a WDH if the tongue weight is low and the trailer is short.
06-17-2013, 09:57 PM
One Happy Camper!
I have an Andersen Hitch for sale. I think it would work extremely well for your requirements. My Wife is also a small woman and she had no problems applying the WD for me while I was doing the safety chains. All you need to do is ratchet down the nuts on the end of the chains. The brackets are bolt on with set screws (no drilling). Sway control is built into the ball shaft. PM me if interested in mine that is for sale. Or look here:
http://www.forestriverforums.com/for...ale-41867.html
SPPD
2013 Palomino SolAire 317 BHSK
Nights Camped YTD: 39
TV: 15 F-250 Crew 6.2 short bed, ProPride Hitch
1995 Jayco Eagle 304 BH sold- March 2013
1978 Nomad 18 sold- April 2005
06-17-2013, 11:02 PM
I used to haul a steel 2 horse bumper pull. It was thoroughbred size and no dressing room. It had a gvwr of 5000 lbs so very similar to yours. I towed it with a ford ranger, dodge Durango and eventually a Nissan armada. I usually only had 1 horse but sometimes 2 in it. I didn't have any issues towing it. The only time I would get even a little sway was if my horse got lazy and literally sat on the butt bar. I never used wdh or.sway control. I very rarely ever saw a 2 horse trailer with it. The ones that did had a dressing room. You can try asking on a horse forum if you want. The one I know of is NC Horse News - Part 1. They have a section called the square you can try.
Another option and perhaps the best one is to go weigh everything. Load your truck and trailer up (with horses) and go weigh it at a local scale. You want a weight of the truck without the trailer hooked up (weigh each truck axle individually) and a weight hooked up(trailer on one pad and each truck axle individually). This is a little trickier for you as you can't unhook a trailer with horses in it. It will require 2 trips for you. Make sure you have a full tank of fuel both times. How much weight has been off loaded from the fro.t axle and onto the rear axle? This will also give you an idea of how much weight the trailer is adding to the truck. The best way to determine your tongue weight is a sherline scale but they are not cheap. Once you have an idea of your tongue weight then you can better proceed. Things to know are what is your hitch rated for (both load bearing and eith wdh). This should be stamped on your hitch somewhere. Also what is recommended by your tv manufacturer for that weight ? If you need a wdh, a good one is Reese dual cam bu. t not sure what size barsyou will need or how low that hitch goes. As for being concerned about hooking up. Your barn muscles can handle it. The hitch head is about 50 lbs. The easy way to snap up bars is to use the tongue Jack to raise the trailer up thereby raising the rear of the truck up and releasing the pressure. I can hand close mine doing this. You will get it. Oh and 1 more thing, make sure you have a good transmission cooler on the truck. I destroyed my Durango towing without one. Good luck.
2014 Sabre 34REQS-6
06-21-2013, 02:37 PM
You seem to be asking about what WDH to get, but also stating that you are willing to accept less than 10% TW on the ball. While a friction sway controller (or the friction sway control from an Equil-i-zer, or the cam system of a dual-cam) will help control sway, you will still feel it, and more importantly, your horse(s) will feel it. Do horses get nausea? Probably.
The fact is that you need to get 10% on the ball to be stable. I hear you saying that most horse owners don't do that, just like most horse trailers don't have power-jacks, etc, etc. But you are not most people. You don't have a 3/4-ton truck, and you don't have a gooseneck. Not having a lot of weight behind the axles is not what helps against sway. You need more TW.
You have room in that front cargo area. You should use that area, and simply secure the load properly so your animals are not in danger. I used to have a popup camper with a front storage truck. These were designed tongue-light, under the assumption that the trunk would actually be used. Otherwise, the rig would not be stable. You have the same situation.
I'm not trying to be a jerk. Please take this as my honest recommendation to you, both for your safety, and for the comfort of your horse(s).
Good luck!
06-22-2013, 11:12 AM
The Andersen hitch is probably your best solution.
Two way sway control built into the ball mount. No bars to snap up. No holes to drill. No parts to grease. No sway brace to remove when backing up. Hitch head (with ball), shank, chains, trailer brackets, and hardware come in a box that weighs 60 lbs. It's lite weight, quiet, and cleaner than any other WD hitch.
Andersen hitch is a little soft on weight distribution for a heavy (800+ lbs) tongue weight, but, you don't have a really heavy tongue.
06-22-2013, 11:41 AM
Good luck!
I just don't think they need the 10% because there is nothing behind the wheels. That is just my opinion and nothing scientific. Look up horse trailers and see.
Locomotive Engineer
06-22-2013, 01:41 PM
You do not need to put something in front of the horse. Horse trailers are designed differently then camping trailers and therefore designed to have a different tongue weight than that of camping trailers. I really think you will get better more appropriate answers from a horse forum.
2014 Sabre 34REQS-6
