12-08-2014, 09:53 AM
WDH creaking and groaning
Is this normal? I have it set up as close to optimal as I can and TT pulls perfectly with no sway or bounce at all. However when turning it really creaks and groans. I don't really care because it pulls so well, but sometimes it is a little embarrassing pulling into places. Is this anything to worry about?
12-08-2014, 09:59 AM
What WDH ?? There are a few things you can do to lessen the noise, depending on the which WDH you are using.
12-08-2014, 10:08 AM
Reese Pro Series with flat weight bars. I do use a VERY light coating of WD40 on the ball and a little spray white lithium grease on the weight bars. Setup looks like this below:
12-08-2014, 10:14 AM
If it were me, I would apply a liberal amount of wheel bearing grease to the large end of the bars and in their socket as well as the hitch ball and the sway bar balls and sockets. Spraying lithium on the chain links also reduces noise.
12-08-2014, 10:18 AM
Wow, I did not realize that you could use that much grease on the hitch components. I guess that is makes sense though...."the squeaky wheel gets the grease"
12-08-2014, 10:35 AM
Just to be clear for anyone coming across this thread later - if your WDH includes friction points intended to reduce or eliminate sway (L brackets on a Equalizer or E2, or the cams on a Dual Cam, for example), those areas should NEVER be lubricated.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
12-08-2014, 10:56 AM
I have the same hitch, the noise is likely coming from the friction sway control. Loosen it up for testing, and I'll bet it disappears.
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2016 - 47 nights
2017 - 47 nights
12-08-2014, 11:34 AM
I agree with Landj, the noise is coming from your sway bar. It may be just a tad too tight but at least you know it is working. Do not put any lubricant on it!!
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
12-08-2014, 12:20 PM
Curious. I have moved the rig without the sway bar on and get the same noise so I am not sure that lightening it would help. At any rate I do not run it with it cranked all the way down anyways, and I would never lube the bar only the ball & socket joint. I guess I will have to experiment some more...
12-08-2014, 12:58 PM
Canadian Member
Incorrect, at least for the Equal-i-zer hitch. Equal-i-zer advises to use a lubricant with their hitch to reduce noise. In fact, they sell a "high performance lubricant" in a small white tube. I apply bearing grease on the friction surfaces of the hitch head and use their "Sway Bracket Jackets" on the L brackets. It still moans some but not as bad as it did without any lubricant.
12-08-2014, 01:40 PM
I guarantee the noise is coming from the sockets on the hitch head.
2010 Chevy Suburban
12-08-2014, 01:45 PM
You can lube the sockets, but lubricant on the L brackets defeats the whole point of having sway control built into the WDH. It would be like putting grease on a sway bar - you might as well not even put the sway bar on.
2010 Chevy Suburban
12-08-2014, 01:53 PM
Must be the sockets, then. Mine is still new.... mine groans like mad from the sway bar. Take it off, and it's silent. Grease it up!
John and Linda
2016 - 47 nights
2017 - 47 nights
12-08-2014, 06:31 PM
My Reese WDH sway bars make a groaning noise when I turn, but it is because of the friction control bars being cranked down tight. I assume, yes, I know what assume means, that it is normal. It's been that way since we bought the trailer, and from what I can find out, they aren't supposed to be lubed, just the balls and sockets. The system works well for me.
12-08-2014, 06:52 PM
Carknocker Family
Whenever I check in at the campsite. I remove my sway control. Lot less noise, and yes I do grease the hitch and the lift bars in the proper spots.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
12-08-2014, 09:06 PM
The Equal-i-zer installation manual states their high performance lubricant on the L brackets is optional to reduce noise, which we use and is very effective. They also have a "slip on" jacket that can be used for the same purpose. Both are for available on their website. The only disadvantage to the grease is the mess it creates when handling the bars. Gloves are a must!
12-08-2014, 09:20 PM
(Dry Huunday)
X1!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
12-08-2014, 10:01 PM
Canadian Member
Techntrek, do you have an Equal-i-zer hitch? If so, you haven't read the manuals or the info on their website. I don't know where you're getting your info because it's not correct.
The manufacturer says you can use lube on the friction surfaces on the hitch head and on the L brackets. I checked with Steve Binks from Equal-i-zer and he confirmed that bearing grease is an acceptable lubricant. I bought the "Sway Bracket Jackets" for the L brackets to avoid the mess using lubricant, but I use bearing grease on the hitch head. I didn't notice any difference in the effectiveness of the anti-sway when using the lube. Just make sure everything is torqued to spec and you're fine.
Even with the lube, it still creaks and moans but just not as much as without it. The creaking and moaning means there is friction and the hitch is doing it's job.
12-08-2014, 10:05 PM
I greased my E4 the first summer... Finally decided this summer that the groans were less annoying than getting grease on my shirt, shorts, hands, etc...
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
12-08-2014, 10:19 PM
Friction Sway Control and Lubrication always (Humorous Reading)! I hope they don't apply their Theories on Brakes!! Yes it is the EASY way for MFG. to (Sell/Tell) customers to reduce Friction /Noise by Lubing! Youroo!!
