Old 08-26-2015, 01:13 PM   #11
Equalizer - noise = BlueOx
Just sayin'
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline   Reply With Quote
Old 08-26-2015, 01:41 PM   #12
New to this forum but not new to camping.
That being said I just installed a Blue Ox Sway Pro to try to control the TW on my Work & Play. I did a no no and didn't get a true tongue weight before hand thinking I knew what it should be. I was not able to get my truck to level out even with a 20K hitch with 2K bars. So I loaded up again yesterday with a full fresh water tank and Cat scaled it and found I have 2360 lbs of tongue weight.
So my lesson to me and others Know what you need ahead of time before buying your hitch.
2017 Wolfpack 25Pack12
08 Dodge Cummins 6spd 4X4 CC
Papa Rich is offline   Reply With Quote
Old 08-26-2015, 01:48 PM   #13
D_B Travelers's Avatar
That is hard to do if you don't have the RV yet and/or new to this. You have to trust the dealer knows what should be used and is going to guide you to the correct hitch. In my case, they didn't and I had to change to a heavier hitch. The WJ literature says the hitch weight was 860#, ah...cough...bull$#!*. I found it was actually 1,075# before I put a single personal item in it! Then I had to wrangle with Fun Town in Cleburne to get them to refund the cost of the original hitch; still waiting on the refund. I know, the check is in the mail...oh boy.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 08-26-2015, 01:55 PM   #14
So i'm confused. On a Toy Hauler I know that the frames are generally beefier to support the weight of the cargo, and that there is less empty weight in the back because of the lack of furniture, but where does all the tongue weight come from? Is there some sort of ballast weight in the front?
Corpus Christi, Texas
TT: 2016 40' Chaparral 360IBL at 14000lbs
TV: 2016 F450 Platinum 6.7 CC LWB FX4, B&W Companion Hitch
IronCobra is offline   Reply With Quote
Old 08-26-2015, 01:58 PM   #15
DB, I understand I was in a similar situation in that I believed what the dealer had told me. They had even contacted the factory to verify the TW.
This is the new style 2016 W&P so there is not a lot of data on it.
Old 08-26-2015, 02:02 PM   #16
VaJim
V-Lite
We love our 2012 rig, but be warned you need to replace all the tires with "E" rated tires. We run ours with 80lbs of air and get a better ride. Try to get your dealer to replace them if you can and avoid blow outs. P.S. enjoy your rig, it it is sweet! Jim
2010 Ram 1500 Quad 4X4 5.7L
2012 V-LITE 30WFKSS
VaJim is offline   Reply With Quote
Old 08-26-2015, 02:03 PM   #17
jeff64's Avatar
I'm using a 14K Equalizer
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 08-26-2015, 02:34 PM   #18
We have a 3008 Windjammer which I think is the twin of your trailer and an Equalizer 12k hitch. The L brackets are mounted at the recommended distance back from the hitch ball (32" I think) with no problems. WDH works great with no sway from passing trucks on the interstate.
As others have said I would recommend changing the OEM tires at the first opportunity. The OEM tires have no load safety factor if the trailer is loaded to max GVWR.
Windjammin is online now   Reply With Quote
Old 08-26-2015, 02:54 PM   #19
Georgia Frog Rally 2018
aceinspp's Avatar
I use the 14,000 Equalizer 4 point WDH on my V-Lite 30WRLIKS After trying 3 different type hitches this the best. My first V-lite was a disaster towing with what dealer had put on. Now I drive more relaxed and enjoy my trips. Proper mount for bars to brackets is 32 inches. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 08-26-2015, 05:26 PM   #20
Angry Thanks All
To be sure I covered everyone, thanks again. Late last night I started collecting measurements for mounting the frame attachment ends of several hitches. I remember one person saying he could not attach Blue Ox clamp on trunnion device due to proximity to the nose of the box (propane tank enclosure).
I don't want to be left like my last rig and I'm afraid dealer will throw something on there just to get us to leave. My Reese Dual Cam/Straightline was mounted a bit to close to the ball and has been a pain to correct.
You had to be there to see where the set up was made. I didn't know much about it then and trusted them. Not anymore!!!!!!
whatsupchuck is offline   Reply With Quote
