Originally Posted by Svtyone
Ok since we're on the talk of wdh.my dealer advised me to remove my sway bar when backing into campsites and such. Should I also remove the bars or leave them connected the reason I ask is where I park I have to basically jackknife the trailer and was thinking that cant be good for the wdh
2 separate things here:
1. If you use a separate friction sway controller (not integrated into the WDH system), do you have to remove the sway controller when backing up?
Answer: It depends.
The stated reason for removing is so you don't damage anything. Simply backing up, even while maneuvering will not damage anything. The forces involved are the same in reverse and forward. The only problem is if you jackknife severely, you could bottom out the "male" portion of the controller in the main female housing. At that point, it becomes like a solid bar, and if you continue the maneuver, you will bend the controller itself, some part of the hitch head, or something on the trailer.
So, you should either:
a. Know the limits on either side, and do not exceed them with the sway controller in place, or,
b. Remove it if you don't want to take a chance.
Note also that this is not a problem for sway control built into a WDH. There are no such limits, that I know of.
2. Should you remove the WDH bars when backing into a site.
Again, simply backing up and maneuvering is not a problem. But I think the question is really, "If my final location for unhitching has the truck at a severe angle to the trailer, is it OK to unhitch in that situation, or should I have removed the bars sooner.".
I have had this situation before, and in the end, I always remove the bars when I get to the final position, not before.
a. If I remove them sooner, there is a good chance that the unlevel terrain could have me dragging and possibly damaging my jack or something else.
b. While I do notice that the bars are unevenly loaded when at an extreme angle (1 is easy to unload, while the other requires the jack to be lifted further to unload), I do not notice 1 side being damaged by this, and believe that the system is designed to handle this sort of loading while stationary.
Experiment with your equipment, and do what makes you feel most comfortable. But I don't think you will find any right or wrong answer here. For backing up the last 20-30 feet, if it makes you feel better to remove part of the equipment, go for it. But try not to block traffic while you do it.
