Originally Posted by nomad297
I have never seen a professional RV transporter use a WDH.
Bruce
Hello, I am a professional RV transporter and the only time I do not use a WDH is when I'm pulling a fifth wheel (for obvious reasons).
Further, the transport company I am leased to requires all tow-away drivers to use a WDH. I know several drivers for other companies and they all use WDH too.
Last week I delivered a 19 foot Summerland Mini to Virginia - used my WDH. Yesterday I delivered a Puma 32BHDB (38 feet long) and used the same WDH.
Most guys use the kind of WDH with the underslung bent bars with snap hooks for the chains. This only requires tightening one bolt on each side of the tongue 'A' frame. I personally use the Blue Ox Sway Pro with 2,000 pound bars because I like the brackets that rotate better than the snap up hooks, and they take up less real estate on the tongue. I've run into a couple campers I had to move the propane line a bit to be able to mount my WDH.
I use a deep cycle battery with wing nuts on the posts and a tie down strap to hold the battery box in place on the tongue. I also wrap a very long bungee cord over the plastic propane tank cover. At the rear I remove the bumper caps and spare tire cover (if equipped) and re-install when I get to the dealership. I also use bungee cords to hang my transporter plate on the camper.
It takes about 20 minutes to do a physical inspection of the unit and hook up. About another 10 minutes to fill out my log book and I'm ready to go.
Originally Posted by timfromma
1. Those trailers are at dry weight.
2. They would have to adjust their WDH each time to match whichever trailer they are delivering at the time.
They probably should use a WDH but I imagine the aggravation of having to readjust their hitches for each delivery is too much of a PITA.
The absolute hardest part is getting the brackets on the frame located so that the chain is vertical. Too far forward or too far back can throw the whole thing out of whack.
As far as tilting the hitch head, my Blue Ox is preset and not adjustable. I will say I have seen some transporters buzzing down the highway with campers really nose high and some really nose low. I have a six inch drop on my hitch and all my pulls are level. Don't know about those "other guys" I've seen, but I can't answer for everybody. No matter what system might be in place, no matter how easy it my be to do a thing, there will always be people that can mess it up.
Dry weight, or not, they are still heavy. They even pull destination/park models without a WDH.
Bruce
Nobody gets off the storage lot without a WDH correctly installed.
