The front axle weight with WDH engaged should be about the same as with no trailer attached. You are 20 lbs heavier with WDH engaged. Congratulations!! Most people don't get enough weight transfer. Technically, you could transfer more, since you have another 400 lbs of front GAWR available. But then you could end up removing too much weight from the rear, causing stability issues. The goal is to get the front back to stock weight, which you have done.
Happy Camping!
