Old 03-08-2014, 05:08 PM   #1
Question Wdh questions
What happens when you use spring bars rated for heavier than your actual trailer.
Say 750 pounds hitch weight with 1000 or 1200 pounds bars ?
Thanks for the info !
Black
Black is offline   Reply With Quote
Old 03-08-2014, 05:21 PM   #2
LaydBack's Avatar
Would be nice to know what setup, but your lack of tongue weight will not allow the hitch to distribute weight back to the trailer axles and forward to the steering axle. This will probably make for an unpleasant towing experience, and in the case of the Reese dual cam, you won't get much if any sway control.
Sent from my SPH-L710 using Forest River Forums mobile app
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 03-09-2014, 10:25 AM   #3
MtnGuy's Avatar
Not sure that I can agree with all of that.
IMHO opinion, heavier spring bars will still distribute the weight, but the ride will be stiffer.
In the case of a deep dip, like entering a service station, the stiffer spring bars will not bend as much as properly sized spring bars, and may actually put to much weight on the front TV axles, and over-stress the receiver and trailer tongue.
When initially trying to setup the WDH on my 700 lb. tongue weight trailer with 800 lb. bars, I didn't like tilting the head assembly back so far, so I bought 1200 lb. spring bars. I did not like the ride with those. The back of the truck felt stiff. I went back to the 800 lb. bars, tilted the assembly head back almost all of the way, and got the weights were they were supposed to be. The 1200 lb. bars are still sitting in my garage.
A 750 lb. tongue weight is getting close to the 800 lb. spring bar upper limit, so 1000 or 1200 lb. spring bars may be needed if proper weight distributing is not obtained in all trailer weight scenarios (camping gear distribution, water tank levels, etc.)
Here is a chart from Etrailer with suggested spring bar uses:
Old 03-09-2014, 11:20 AM   #4
SKnight's Avatar
Attachment 47413
Agreed, it'll just be stiffer. Plus you can tailor the stiffness some with head tilt or which chain link is used if that type. My first tv I needed to use the fourth link from the top, the second tv, a 2500 with HD suspension, I found it incredibly stiff on the fourth link so I dropped to the third link and tweaked the head tilt a little.
The bars are up to 1200 pounds, if you don't set them up too tight it'll behave the same as 800 pound bars set up tight, for the most part at least.
Old 03-09-2014, 12:46 PM   #5
According to Equal-I-Zer there will not be too big of a difference if you are within 300-400 lbs of the rating. They use spring steel in their bars, and the spring rate is more progressive the more they flex. Thus they said there might be a slight difference in ride, but most notice nothing, ASSUMING you have it adjusted properly.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
