Old 06-09-2016, 12:47 PM   #11
Georgia Frog Rally 2018
aceinspp's Avatar
The only trailer I never needed a wdh was a 24 ft enclosed car trailer towing with a dully. Never a sway problem till I started towing TT. No way to really adjust tt weight to not to be able to use a wdh. Lter RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-09-2016, 12:50 PM   #12
(Dry Huunday)
DreiHunde's Avatar
Originally Posted by doc73 View Post
I still use WD, I think it still tows much better even if the trailer and truck may not "technically" needed.
Ditto
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 06-09-2016, 01:05 PM   #13
Professional Curmudgeon
I have two TT's; one has a tongue weight of about 980 lbs. while the other only weighs about 450 lbs. My hitch is rated for 600 lbs. weight carrying. I use the WDH on the heavier camper, but just a plain draw bar on the lighter one. I have pulled both several thousand miles without any issue.
Pulling a TT with a tongue weight below what your hitch is rated for is no different than carrying a load in the bed of the truck.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 06-09-2016, 04:39 PM   #14
My issue is the method used for adjusting my WDH (Equal-i-zer) is how much the front wheel-well changes when the TT is hitched. The rear wheel-wells on my F-250 lower significantly with and without the WDH, but the front only raises about a 1/4". Putting a minimal amount of lift from the WDH bars gets the front wheel-wells back to the unloaded position.
I guess the only way to be sure is to weigh the TV and TT combo with and without WDH, but even then, I am under the impression that you never lower the front wheel-wells lower than when unloaded.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 06-09-2016, 08:42 PM   #15
This statement could not be more wrong.
Towing a TT puts a bunch of weight far behind the rear axle. This is the reason for WD.
A load in the bed is normally distributed much better, which would be like towing a 5er.
If the load in the bed is all the way in the rear, it is still a foot or more closer to the rear axle than a TT's tongue weight.
325BH is offline   Reply With Quote
Old 06-09-2016, 09:31 PM   #16
I would submit your statements are incorrect and argumentative. For example - a statement that contains the word "normally" is a statistical assessment that I doubt you can back up with any kind of evidence. When I put something in the bed of the truck at, say, Lowe's or similar, that I have to unload by myself when I get home, I invariably put it as close to the tailgate as I possibly can and still close the gate, and since the ball of my hitch is less than six inches from the receiver, I'd say it's close enough to make my statement true.
Where the pin weight of a fiver is distributed is not the same as your hypothetical load that is evenly distributed across the entire bed, either.
And since I didn't invent the WDH I won't pretend to know why it was invented, but since I do understand how it works I'd bet getting weight back on the steering axle is more important than reducing weight on the rear axle.
Old 06-09-2016, 09:42 PM   #17
head gamez's Avatar
Personally, I would pick up a heavy duty ball mount and go with it (as long as the hitch weight is less than the hitch rating).
Honestly, if you read too much on the the internet then you would end up with a Freightliner truck to pull the smallest of travel trailers.
I roll with my 24' race car trailer on a HD ball mount, and have pulled a 32' trailer with two race cars in it on the same ball mount.
Careful when reading the Internet. It can cost you allot of dough!
2016 Sandpiper 376BHOK
2500HD Chevrolet
head gamez is offline   Reply With Quote
Old 06-10-2016, 07:33 AM   #18
Yesserree...and the longer the wheelbase the better....go with an 8ft bed..
Save a beer for me!!! Happy Trails....Be Safe....
sunnyinfla is offline   Reply With Quote
Old 06-10-2016, 07:42 AM   #19
Originally Posted by sunnyinfla View Post
......and the longer the wheelbase the better....go with an 8ft bed..
X2
Springerdad is offline   Reply With Quote
Old 06-10-2016, 07:45 AM   #20
X2
truck
