Old 06-09-2016, 11:05 AM   #1
WDH with 3/4 and 1 ton trucks
I've been eyeing some heavier trucks. Mainly 3500hd crew cab srw chevies. I've also seen a used 2015 3500 hd dually crew cab. and looked at a few 2500hd trucks. All with diesel.
This leads me to ask this question since I've always had 1/2 ton (silverado 1500) and always used wdh and sway control.
Do you really need the wdh once you start using the heavy duty trucks to tow with?
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
Old 06-09-2016, 11:10 AM   #2
Yes. No matter how heavy duty the truck, a bumper pull removes weight off of the front axle. A WD hitch puts that weight back on the front axle.
A light front end makes for bad towing.
Now, how heavy the truck and how heavy the trailer are things that you must evaluate in a WD need or not.
325BH is offline   Reply With Quote
Old 06-09-2016, 11:11 AM   #3
A WD hitch also lifts the rear end. That is less of an issue the bigger truck you get.
Unloading the front is still an issue.
Old 06-09-2016, 11:11 AM   #4
Who Dares, Wins
doc73's Avatar
I still use WD, I think it still tows much better even if the trailer and truck may not "technically" needed.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-09-2016, 11:29 AM   #5
I use a WDH with my 3/4 T
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-09-2016, 11:36 AM   #6
A lot of states have laws that require wdh and brakes based on weight of trailer. I use mine with my 1 ton, and on my landscape trailer when carrying anything over 4K.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 06-09-2016, 11:41 AM   #7
YES you do.
David and Vicki
8 year old Springer rescue Sydney
2018 Silverado LTZ 3500HD Dually Crew Cab Duramax/Allison stock "Polar Bear"
2019 Grand Design Reflection 337RLS "The Dog House II"
Andersen Ultimate 5th wheel hitch
EezTire TPMS
Springerdad is offline   Reply With Quote
Old 06-09-2016, 11:46 AM   #8
jtstromsburg's Avatar
Yes, but once you switch to a fifth well, it's much easier. 😁😁😁👍👍👍👍
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 06-09-2016, 11:56 AM   #9
I figure I'll end up with a 5th wheel someday, so next truck will be a 3500HD. Whether or not it's srw or drw is the only question.
Old 06-09-2016, 12:33 PM   #10
thebrakeman's Avatar
The Ford Towing Guide calls for a WDH on even the heaviest vehicles, when TW exceeds 500 lbs.
thebrakeman is offline   Reply With Quote
truck
