Old 04-17-2016, 10:39 PM   #1
Weighed truck and toy hauler
Trailer weight is 8,380 lb.
I do have 1,780 lb tongue weight,I didn't have any toy in garage this trip.
Is there any way to reduce tongue weight? Fill fresh water tank?
ID:	105275   Click image for larger version
ID:	105276   Click image for larger version
2016 Hyper Lite XLR 30HDS
2015 GMC Sierra Denali 3500 DRW
GMCdiesel is offline   Reply With Quote
Old 04-17-2016, 10:47 PM   #2
BigDaddy1967's Avatar
Put toys in the back to reduce tongue weight. If fresh water tank is aft of ty our axles, it will reduce tongue weight, but guessing tanks are located pretty close to axles.
2014 Ford F250 Super Duty, 6.7L Diesel, Ultimate Lariet package
2016 Forest River, Heritage Glen 272RL
BigDaddy1967 is offline   Reply With Quote
Old 04-17-2016, 10:48 PM   #3
trbomax's Avatar
We cant answer unless we know where the garage and*water tanks are in relation to the axels.
trbomax is offline   Reply With Quote
Old 04-17-2016, 11:00 PM   #4
I'm not sure where water tank is,I was hoping someone here will know.Garage is in back behind axles.
Old 04-17-2016, 11:06 PM   #5
Usually Confused Member
emm-dee's Avatar
One of the reasons I'm working on putting a 50 gallon water tank about four feet behind the rear axle. Just have to locate the right size tank. It will be used for ballast when the motorcycle is not loaded.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 04-18-2016, 07:05 AM   #6
fonzie's Avatar
I think your tongue weight is: 10,600 - 9080 = 1,520 lbs
using figures when no wdh is used minus truck weight.......
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-18-2016, 07:44 AM   #7
WolfWhistle's Avatar
x2 you have 1520# TW. Your TWR is 18%. Your trailer weighs 8380#
If on my 29HFS I were to load a 1000# motorcycle on a chock as far forward in the garage as possible, tongue weight is reduced by 154#. So, about 1154# more is on the axles. But, of course, lengths and positioning will be slightly different on your model.
When I add 450# of fresh water (my tank is nearly centered between tongue and axle pair center), tongue weight increases by 215#.
Where is your FW tank? if behind the axle pair center water would lighten the TW; if forward it will increase it. I bet it is forward.
If you have the fueling station, weight back there would also lighten the tongue.
BTW, my TW was 1260# with no water and not toys before I added 120# of batteries and #80 in solar gear... I need to reweigh.
WW
Name:	under floor.jpg
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 04-18-2016, 12:29 PM   #8
RVBikers's Avatar
In my case, I have about 1250# tongue weight without our bikes in the back, so I would move coolers, chairs, grill, etc. to the back to take some weight off. However, when the bikes are in it takes too much weight off and I have to put water in the fresh tank to put more weight back on the hitch.
Jim & Evelyn
-2015 Ford F-350 XLT Dually
-2016 Prime Time Spartan 1242X
-2012 Harley Davidson Street Glide (his)
-2004 Harley Davidson Fatboy (hers)
RVBikers is offline   Reply With Quote
Old 04-18-2016, 02:56 PM   #9
Just curious, but were you fined for your trailer? Those docs in the images you sent seem to show a fine and court date.
If so, then what state makes you pull off at a weigh station? I will be sure to avoid such states.
But even so, what are you in violation of?
MOODMAN is offline   Reply With Quote
Old 04-18-2016, 03:07 PM   #10
Fulltime family RVer
Fine and court date? I'm the original post, the 3 slips are pretty standard weight slips from a truck stop scale. Looks like he went to a Pilot in Illinois. There is no one there to fine you or even care what your actually weights are.
Or am I missing something?
On edit: I do see it says Fee: $2.00 on one; that is the cost to for a reweigh.
toy hauler, truck
