Originally Posted by 007matman
I've said it before but I'll say it again.. you want the vehicle at what you would consider your optimal ride height prior to hooking up your trailer. You DO NOT want to use the air bags to get at your optimal ride height with the trailer connected (and no weight on the WD system).
Doing so negates the value of having the WD system engaged and you'll have a heck of a time dialing things in to get any pressure on the bars.
Unhook the trailer, get things at the height you think is optimal/level, make your measurements and adjust your hitch to fit properly. After you have everything connected and you see both the front and rear settle approximately the same amount, then use the air bags to bring the rear up slightly (if needed).
With a proper dialed in WD hitch you shouldn't need the air bags at all. They really should just be used to level it out if cargo capacity (example: People) makes the rear sag a bit.
That's my two cents worth. This is the only way you're going to be able to shift the proper weight up front.
Sorry but while your first statement is correct your instructions are incorrect. The WD hitch is used to distribute the tongue weight between the steer and drive axles. Air bags in no way change the tongue weight the hitch is working with. The air bags accomplish 2 things, firm up the rear suspension and allow you to restore ride height. Changing the spring rate of your suspension in no way subtracts from the tongue weight of your trailer. You should set your air pressure with your trailer on with no WD bars first, then adjust your WD hitch to distribute the tongue weight.
I have quite a bit of towing experience with a variety of hitches. Airbags have allowed me to dial things in that much better and firming up the rear suspension has improved both ride and control with no effect on WD. I scaled my rig and airbags in no way prevented me from adjusting my front axle bias as needed.
At the end of the day air bags are no different than swapping in a leaf pack with a much higher spring rate. They are just adjustable allowing to go back to a softer suspension when not towing.
The reason all hitch documentation tell you adjust your airbags first is so you can set the trailer level via the hitch once the ride height of the tow vehicle has been established. You do not want to add air after the fact as you suggest.
