Old 02-19-2016, 11:57 AM   #11
thebrakeman's Avatar
Originally Posted by 05CrewDually View Post
We have 2, his & hers. I'm 175lbs. on mine, same as the doctor's scale. Her scale tells me I'm only 135. Weird!? I'll stick with using my scale.
On a serious note, using 2 scales you're bound to overload 1 of them. Even splitting the difference of 750lb tongue weight, you're looking @ 375 on each. My scale doesn't go that high plus it puts it in a less accurate calibrated range in my opinion.
Here's an even better write up.
https://www.etrailer.com/faq-how-to-...ue-weight.aspx
The question on this post is whether the OP's TW will be greater than 500 or not. Not sure where you are getting the 750 lbs TW. Like I said, lower the tongue slowly, just in case you are not centered well, so neither exceeds 300 lbs. But even eyeballing the center, this should not be a problem in this case.
thebrakeman is offline   Reply With Quote
Old 02-22-2016, 01:54 PM   #12
Had the e2 installed today. I'll give update after our first road trip.
Sfogle is offline   Reply With Quote
Old 04-02-2016, 10:15 PM   #13
Maiden voyage for the wolf pup. 600 miles with the e2 hitch. What a difference! Best money I've spent.
Old 04-04-2016, 11:10 AM   #14
E2 is a nice choice for that rig.
Just in time for camping season!!!
hitch, weight
