Old 11-18-2019, 05:18 PM   #1
Zigger
Weight distribution hitch
Got a new 2019 f250 super duty to tow trailer. 28ft. And about 8k lbs. The truck has a weight distribution hitch already on it from the tow package with anti sway. Do I need the weight distribution hitch with anti sway bars on the trailer? Used to fifth wheels.
Thanks!
Zigger is offline   Reply With Quote
Old 11-18-2019, 05:48 PM   #2
bikendan's Avatar
Depends on your truck's payload and the actual loaded tongue weight.
Equalizer WDH
Old 11-18-2019, 05:49 PM   #3
007matman's Avatar
Hotly debated topic.
I use one with the 32' 7600lb trailer pulling with an F-350 DRW LWB
007matman is online now   Reply With Quote
Old 11-18-2019, 05:51 PM   #4
BigH's Avatar
Thanks!
Welcome to the site.
First, the anti-sway built into the truck is an emergency fail safe designed to keep you from wadding it up while control is being lost. Meaning things aren't going well when that feature kicks in...
Second, your manual will tell you when a an accessory wdh (weight distribution hitch) is required for your specific cab/bed/wheelbase configuration. This requirement (limit) was determined by the SAE J2807 tow test.
Proper trailer design and loading is critical, this demonstration may be of some help:
17 Chevy 2500 DC Long box Gasser Z71 4.10
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 11-18-2019, 05:53 PM   #5
Multi-Slacker
A properly set up hitch will provide a degree of safety and improved comfort that you will not have without. JMO
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / 2700 lb 2.5" Receiver
CurtPutnam is offline   Reply With Quote
Old 11-18-2019, 05:54 PM   #6
AZ Pete's Avatar
short answer, yes.
AZ Pete is online now   Reply With Quote
Old 11-18-2019, 06:01 PM   #7
Zigger
Thanks for the info!
Old 11-18-2019, 06:53 PM   #8
Brake is on left
The Evil Twin's Avatar
Thanks!
If the previous owner had a WDH it may or may not be the correct spec for your trailer. Double check the capacity info on it before anything.
My Blue Ox w/ sway control suggests turning the truck sway control off when towing with it. I often forget. My old TV you could feel the sway control fight the hitch sway control.
The Evil Twin is online now   Reply With Quote
Old 11-19-2019, 12:41 AM   #9
Just a member
kandl's Avatar
Did the dealer install the WDH? They typically don't do that. Nevertheless, at 28 ft, your TT is definitely gonna need a WDH. Sway control too!
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge Ram 3500
kandl is offline   Reply With Quote
Old 11-19-2019, 05:09 AM   #10
BigH's Avatar
https://www.fleet.ford.com/resources...e_r2_Dec21.pdf
A wdh is designed to shift weight back to the front axle to correct a potential handing issue induced by tongue weight. Trailer length doesn't determine when a wdh is required or needed. This handling issue is found by the testing I mentioned earlier...my understanding is trailer tongue weight is increased until the lateral deflection reaches a certain amount during testing.
Every manufacturer is different and are given limits per the same testing. For Chevy the long wheel base (my truck) a wdh is not required all the way to the receiver tongue weight limit of 2000lbs. I don't use a wdh with my trailer and 1500lbs tongue weight. Over 10,000 miles of relaxed towing at any speed or condition.
If you want to have an opinion that a 28 foot trailer requires sway control...you would have a better argument but proper loading (tongue weight) while keeping weight from behind the trailer axle is still the key to mitigation here if someone wants to understand why.
18 Vengeance 28V
hitch, weight, weight distribution hitch
