Old 11-15-2015, 06:55 PM   #1
danielabram71's Avatar
Weight distribution hitch
I have a question. When using a weight distribution hitch. The connection brackets that go on the A frame of the camper. I know you snug them down. But should they be able to move while towing? I had them move one time and my propane tank holder almost came off my camper. Or is that normal?
danielabram71 is offline   Reply With Quote
Old 11-15-2015, 07:07 PM   #2
Wobbles's Avatar
My first thought is that the setup is all wrong. Seek a reinstall/new remedy. Sounds like you have trouble and should resolve it. IMO the brackets should not move. Safety...
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 11-15-2015, 07:08 PM   #3
SCCS's Avatar
No way is that normal.
We would need to know the brand of wdh you are using to better understand the situation.
SCCS
15 F150 xlt pulling
15 Forest River mini-lite 2502s
SCCS is offline   Reply With Quote
Old 11-15-2015, 07:08 PM   #4
You need to tighten them down real solid, they should not move period.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is online now   Reply With Quote
Old 11-15-2015, 07:38 PM   #5
OK. I do have them tight now. Like I had them. I was just told be a couple people that the reason you only tighten them to snug then a 1/4 turn was that in the right situation is that if there was no give it could twist your frame on the truck or camper. How ever I have them sit now at snug 1/4 turn per oem
Old 11-15-2015, 07:41 PM   #6
I have a haul master. But this happen with Curt
Old 11-15-2015, 07:44 PM   #7
One thing you want to make sure is that you have at least 6 links of chain between the bars and the lift brackets.
2007 Surveyor SV230
hitch, weight
