Old 05-10-2012, 08:33 PM   #11
Originally Posted by camper_Lucy
Couple of things, First find your yellow sticker (on a cabinet door someplace in the camper) that is the actual weight of the camper as built. Then depending on options add whatever the dealer put on (in the dealer added the battery, spare, etc) to that number. Now you at least have a real starting point to estimate from and determine if the numbers are making sense.
Next, by definition a WDH is supposed to distribute part of the load to the front axle, so something is either not right with your setup or the scale. The weight on the front axle should be higher with the TT hooked up.
Which WDH do you have? Have you measured TV drop with and without the TT hooked up?
I have the Equalizer. I haven't measured that yet. That was going to be my next step depending on everyone's feedback.
sellis1053 is offline   Reply With Quote
Old 05-10-2012, 08:39 PM   #12
Originally Posted by herk7769
I am sorry, but I can't tell you a whole lot from what you posted.
The actual camper wheel weight is critical to the calculations. There should be three axle weights Front; Rear; and camper.
Also are the "hitched" weight of the tow vehicle with or without the WD bars installed? I suspect it is without bars since the nose weight is less than the unhitched weight.
IF, and it is a BIG if, your WD bars are not connected, then your tongue weight is (the sum of the two TV axles hitched) minus (the sum of the two TV axles unhitched) or 6580 - 5700 = 880 pounds
If your WD bars WERE on, there is no way to calculate the tongue weight because some of it would be carried on the camper's axles.
As stated by Donn, DRY weight means nothing and is a meaningless number even on the brochure. The yellow "as built" weight is the true starting point. Actual loaded weight means everything.
It would be nice to know what the camper weighed so we can calculate whether you are safely loaded.
The actual tongue weight should be between 10% and 15% of your actual gross trailer weight for safe towing characteristics.
I measured the hitched weight with the WD bars installed. I didn't weigh the camper by itself. Hitched it weighed 6100 lbs. Besides the GVW of both the TV and trailer, I wanted to make sure my rear axle weight was within specs with the trailer hitched.
Old 05-10-2012, 08:40 PM   #13
Herk7769's Avatar
Originally Posted by itat View Post
I'll be taking the truck and trailer to a local truck stop certified scale. Is there anything I should know before hand?
There is a thread here that explains it all, but it is faster to re-type it. I will also post some reading material.
It is very important to have the camper loaded as you would be driving it camping. I do my weights on the Wednesday prior to our departure on a Friday for example. Family in the car; full tank of gas; propane topped off; food and beer in the fridge; clothes in the drawers.
1) Hook up with the WD bars installed and drive to the scale.
2) Tell the operator you will want 2 weighs and then drop the camper and get a reweigh. (total of 3)
3) Put the front axle on the first platform (get out and check that it is totally on the first platform as it is the narrowest of the scales) and get out and look to make sure BOTH of your campers axles are on their own plate and your rear axle is on the second plate.
4) Get back in and wave to the operator (or press the button) to get your first weigh.
5) Get back out and REMOVE your WD bars and put them in the truck. Wave to the operator again (or press the button) to get your second weigh.
6) Drive off the scales and go to a safe place (there should be plenty of parking around the scales and DROP your camper.
7) Drive back on the scales and put the truck in exactly the same place (front tires on the first plate; rear tires on the second). Wave to the operator (or press the button) to get your final weigh.
Drive off; hook back up; pay the man for a weigh and two "re-weighs"; bring the weight slips back here and we can look at the numbers and give you the score.
5th wheels only need two weighs - hitched and unhitched.
Name:	Camper photos 004.jpg
ID:	13564   Click image for larger version
Name:	Camper photos 005.jpg
HAM CALLSIGN - KC3FFW
Old 05-10-2012, 08:46 PM   #14
softwarejoe's Avatar
How would you recommend weighing tv and tt on a 100 foot long commercial scale?
Moose Jaw Saskatchewan
2012 Surveyor 305 B-309
2010 F-150 4x4 supercrew Lariat 5.4 3.55 ratio
Power moon roof and back window
TV GVW without me 1/4 tank 5870 lbs
Days camping 20011-4 2012-26 2013-29
softwarejoe is offline   Reply With Quote
Old 05-10-2012, 08:50 PM   #15
Herk7769's Avatar
One single platform?
No way to do it.
CAT scales have many platforms so you can place an axle on each.
Find one near you.
CAT Scale
Old 05-10-2012, 08:51 PM   #16
Canadian Member
itat's Avatar
Thanks, Herk. I didn't know there are supposed to be multiple plates. I'll stop by the scales this weekend to check that they do. I'll be getting my weights on the 17th or 18th so I'll check back then.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 05-10-2012, 08:55 PM   #17
Herk7769's Avatar
Here are your locations:
45 miles
View Map Husky Truckstop1755 Prince of Wales Drive, Regina, SK S4Z1A5
134 miles
View Map Husky TrucskStopHwy 16 & Marquis Drive, Saskatoon, SK S7R 1B6
250 miles
View Map Flying J Travel PlazaI-94 & Highway 16, Beach, ND 58621
Old 05-10-2012, 09:02 PM   #18
Canadian Member
itat's Avatar
Found my local scale at the 5th Wheel on the CAT site so I'll have no problem.
Old 05-10-2012, 09:02 PM   #19
Herk7769's Avatar
If your WD bars were installed there is a problem with your hitch setup.
Your front axle is lighter with the WD bars in place. This is exactly incorrect. The WD bars are supposed to "distribute" a portion of the tongue load ONTO the front axle; not remove it.
Old 05-10-2012, 09:04 PM   #20
Herk7769's Avatar
Awesome. Print out my post and take it with you when you go.
That way you won't forget a weigh when the big rigs are in line.
Do NOT let them rush you. You are paying for the scale just like they are and for the same reason. You want to be legal and safe.
led pad
