Old 06-10-2013, 09:19 AM   #1
Deryll1's Avatar
Weight question
Hey folks, I have a couple of questions, probably asked before but I couldn't find the answer. So here we go:
1. The gcwr( gross combined weight) does it incl the tongue weight too or just the trailer+ truck?
2. The sticker on my TH says 5206 lbs. dry weight, does this incl the tongue weight or just the trailer?
I am crunching numbers to not go over my gcwr, so everything is helpful.
Deryll1 is offline   Reply With Quote
Old 06-10-2013, 09:25 AM   #2
As I understand it, it is total weight of the truck and the trailer, as weighed on the truck scales.
The dry weight of your trailer is the total weight of the trailer empty,(tongue weight included) and I think that is without propane and battery.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 06-10-2013, 09:50 AM   #3
Deryll1's Avatar
Thanks, that's what I thought. But still leaves me the question of the tongue weight incl in the gcwr. Only way to figure it out is probably driving on a scale....
Old 06-10-2013, 09:58 AM   #4
TURBS's Avatar
That is the only way.
And fully loaded ready for camping.
Passengers
Wood
Dogs cats
Camping gear
Genny
Full of fuel
Etc etc etc
Dry weight is a number you should never ever go by as its as the camper comes of the assembly line and will never ever be that number again.
Old 06-10-2013, 09:58 AM   #5
You'll violate all kinds of other limits long before you ever get to GCWR so don't even worry about that one. But yes, GCWR includes tongue weight.
Old 06-10-2013, 09:59 AM   #6
William
WEMig's Avatar
GCWR is the total weight of the tow vehicle and the camper. Hitch weight is already factored in the weight of the entire rig (TV/camper).
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 06-10-2013, 09:59 AM   #7
TURBS's Avatar
Cargo carrying capacity comes to mind.
Old 06-10-2013, 10:06 AM   #8
The GCWR is the is the rating for the total wt of the truck, trailer and all your stuff. This includes the pin wt. Drive on the scales all hooked up and fully loaded,weigh the TV front axle, then the back, pull fwd and weigh all trailer axles. Take the total and it should be under the GCWR. If over its time for a bigger TV or just live with it.
Bruce & Lori, both Retired, Charli (60 lb lap dog)
2011 F350, KR, 6.7L PSD, 6 1/2' box
2015 Mountaineer 331RLT
Charli is offline   Reply With Quote
Old 06-10-2013, 10:33 AM   #9
Deryll1's Avatar
Thanks! Scale here I come!
Old 06-10-2013, 10:40 AM   #10
Always Learning
Is it a travel trailer or fifth wheel?
If it's a TT- you need to get 3 weights:
- Truck + Trailer with WDH bars in place
- Truck + Trailer without WDH bars (bars in the truck bed)
- Truck only (bars with the trailer)
If it's a FW- you only need 2 weights:
- Truck + Trailer
- Truck only
For all weightings, you want to get weights for each individual axle (truck's front axle, truck's rear axle and then all camper axles can be combined).
Old 06-10-2013, 02:33 PM   #11
Deryll1's Avatar
Well, the dry weight as it sits is 5206 lbs. (actual weight since it was weight before I bought it. I weight everything I put in and it's now 6570 lbs. my TV is a 2008 suburban with 7000 max towing. Passengers together are 360 lbs. that's the numbers I have right now before the scale....
Old 06-10-2013, 02:34 PM   #12
Deryll1's Avatar
It's a toy hauler....
Old 06-10-2013, 03:16 PM   #13
Always Learning
On your Suburban - do you know what your cargo carrying capacity is? Usually looks something like this:
Even better if you have this sticker:
(Note, these are from 2 different vehicles.)
Old 06-10-2013, 03:47 PM   #14
Taylorgso's Avatar
Remember that the tongue weight is not a weight separate from the weight of the trailer... it is a function of how the trailer is loaded and the balance from front to rear. You can change the tongue weight (within reason) by shifting the load of the trailer. The GCWR is a function of the chassis manufacturer's design of how much weight their chassis can safely handle.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 06-10-2013, 05:04 PM   #15
Deryll1's Avatar
Cargo carrying capacity is 1510 lbs.
Old 06-10-2013, 05:08 PM   #16
Deryll1's Avatar
Sorry, it's 1593 lbs...
Old 06-10-2013, 05:25 PM   #17
Denver, CO
garbonz's Avatar
you will probably be over your payload capacity then, I can almost gaurooonnteee it. But maybe under everything else, if you are lucky.
IMO of course.
2017 Fuse 23T
Old 06-10-2013, 06:04 PM   #18
Deryll1's Avatar
??why? Payload is tounge weight+ passengers + cargo inside the car.
Old 06-10-2013, 06:10 PM   #19
Always Learning
Generally speaking, we way underestimate our weights when calculating payload. I was shocked to find that my family and I (and ALL of our stuff and add-ons for the truck) came to 1,200 pounds alone. I'll admit, I could use a 80 pound diet myself. But, I wouldn't have guessed it was that much.
A trip to the scales will teach you a ton.
Your toy hauler likely has a tongue weight of between 10% and 15% of its actual loaded weight. It'll likely be a higher percentage without toys.
I don't know if you will or won't. Scales will tell you.
Old 06-10-2013, 06:50 PM   #20
asquared's Avatar
The first thing you need to do is better understand your trucks capabilities than just my truck can tow x lbs. (I learned this the hard way). Most TV are limited by their payload. To find out your TVs true towing capacities then you need to go weigh it. Load the tv up with all occupants, pets, and cargo that will be in it when towing plus a full tank of fuel and then go weigh it at a local scale (CAT Scale ). Weigh each axle on a separate scale pad so it will give you a breakdown of front and rear axle weights individually and a total weight. Take the total weight and subtract it from your Trucks gvwr to get your available payload. Take the scaled Truck weight and subtract it from your Truck gcwr to get your adjusted towng capacity.
Next understand you will never tow an unloaded or dry trailer. Those numbers are somewhat irrelevant. You can either add the amount of weight of cargo you will tow to the dry weight (this is heavier than you think as most add 1000-2000 lb of gear) or simply use the tt gvwr to do your calculations. Being that this is your first tt, using the tt gvwr is the safer route for you. Next understand that the tt loaded tongue weight needs to be subtracted from your available payload. The loaded tongue weight is typically 13-15% of the loaded tt weight. For your purposes go with 13-15% of the tt gvwr.
As stated above weights add up quickly. my family of 3 has added almost 1500 lbs to our TT and its not even a toy hauler. I learned the hard way that my old armada had a stated towing capacity of 9100 lbs but only had an available payload of 810 lbs. This would have limited me to a loaded trailer weight of around 6000 lbs. I didn't understand this and bought a TT that ended up being 7000 lbs and it proved to be a very bad experience. lets just say it went from being a white knuckle experience to being a very scary experience when the armada couldn't hold the TT back going down a 7% grade.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
