Old 06-21-2015, 05:08 AM   #11
Oaklevel's Avatar
This question is to the OP. and something to think about. In Virginia you have to register the trailer (camper) by what it can haul. "Gross Weight", I do not know about other states. If there was an accident and no scale weight would not the courts go by what the trailer is registered for or its gross weight and if the truck is capable of 7000 lbs and the gross weight of the trailer was 9000 lbs. Is not the owner in deep poo poo...............
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 06-21-2015, 06:27 AM   #12
mud yapster's Avatar
More truck is always better than not enough truck.
Goes back to what I constantly read on threads; I'm buying a TT and it weighs ????# I am looking at the F150 or F250 SRW.
I say why cause you will be over loaded. Get a 1 Ton dually diesel and you will be far ahead of the game but even with a new dually diesel you better pick the right tranny and axle ratio or you will still be overloaded. Truck manufacturer's are putting 3.42 axle ratio and the likes so they can get better mileage. You should watch out for that and choose your axle to what it should be for what you are towing now and what you might in the future.
There is no such thing as to much truck so I never understood why someone would buy a 1/2 or 3/4 ton truck to tow such heavy loads just because the dealer says it will. Pulling a RV with a tow truck at max or more will be dangerous and cut the life of your TV significantly. Same for RV's towing them at or over the gross weight. People wonder why their tires blow up when they drive 65 mph overloaded and inflated properly. I also think people don't count all accessories in the RV including propane weight, water load, battery, generator load ext.... Take for example my 5er is 42' yellow stick 12,962# empty, add my accessories and I'm at 17,250# with a GVWR of 18k so ok I'm good there. Now my truck 2015 Ram 3500 DRW 4x4 long bed 6.7L diesel with 3.73 axle and a Aisin tranny, GVWR 14,000# GCWR 32,300#, max trailer weight 23,510#, max pay load 5680# truck empty 8700# so plenty of truck.
Do us all a favor and tow within the specs. it could save your life and mine and you will feel more comfortable towing also. My truck doesn't even slow down for hills but I still tow my big 5er at 60 mph in the slow lane because I'm on vacation going camping.
Happy Camping and think before you tow your TT, 5er, or MH and ask why you put what you did in your RV are you going to use it or not. If not then leave it home.
And don't foreget in most all states if your TV GVWR added to your RV's GVWR is over 26,000# then a Class A licence is required but not a CDL class A unless your hauling for business use.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 06-21-2015, 07:01 AM   #13
B and B's Avatar
Weighing is important! Need a baseline to know where you are coming from. I have weighed every set-up I have and weighed them fully loaded during a trip as well. The weight can creep up to the maximum pretty quickly and knowing where you are is important.
I towed with a F150 5.4 Screw, worked with the TT but near limits, bought a new Ecoboost F 150 Screw with all towing gear and this worked just fine well within limits. Along came the fifth wheel still within most posted limits on weight and towing capacity but. I my experience and where we are planning travelling not suitable. Bought the F 250 Super Duty with Power Stroke Diesel and have the extra stability, power and braking capacity I did not have with the F 150.
For my situation the F 250 meets and exceeds the need, we will upgrade but 90% of where we camp is forested parks and a long 42 ft trailer just won't work. We are looking at a 37 ft Fiver that will have pin weight capabilities of the CCC of the truck.I won't have any other problem with towing other than this. We are looking at a Columbus as a matter of fact.
Many people can not afford a specialized TV that is a dually 1 ton with length no parking spot, parking garage or even driveway can handle. Using a F 150 wisely and within limits suits many most people. A weekend warrior or taking a couple weeks a year at the local lake can bet served just fine by a F 150 or 1500 series truck but affordable and still used as daily driver. Keep the weights in line, put LT tires on the TV, maintain both TT and TV and finally keep speed within safe limits.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 06-21-2015, 09:02 AM   #14
I am within ratings on everything and my truck and trailer stickers were right on when I bought them. I weighed my truck on the way home from the dealer when purchased new.
I am 700 lbs under GVWR on truck with 1500 lbs to spare on each axle. Trailer is 300 lbs under GVWR with 7200 lbs on 8000 lbs of axles. Upgraded to E tires on trailer so no problem with weight there.
I am close on GCWR only under by 350 lbs, but my little 5.4L hauls the load admirably. I have 17K miles towing and 82K on the truck now. Will put another 4K towing miles on this summer. Couldn't be happier with my F250/Flagstaff combo after 5 years.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-21-2015, 09:16 AM   #15
CWSWine's Avatar
My state is the same way. You pay set fee for every 1,000 of the gross loaded weight of your RV not dry weight. I'm not lawyer but I bet it would up to you to prove that you were below that rating and if that rating exceeds the GVWR of your truck you could be in trouble. Just a guess and hope I never have to find out but I believe it would be a up hill battle. Good Point!
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 06-21-2015, 09:26 AM   #16
CWSWine's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
You are a perfect example. If you had diesel instead of the 5.4 you would be at or over your GVWR but according to the tow guide the diesel could pull a much heavier RV then you are pulling. This is what got me into trouble on first RV thinking I purchased enough truck (3/4 ton Diesel) thinking I had upgrade room from Cougar 28SGS (30 foot) RV but found I was already max out.
Old 06-21-2015, 09:40 AM   #17
CWSWine's Avatar
Originally Posted by kandl View Post
Excellent advice! I suspect many RVing folk out there can relate to your revelations. And, if I may, I'm thinking that you've been thinking that... should have bought a dually.
I have thought about dually but it won't fit in my garage and my HOA doesn't require you to keep it the garage but recommends that you do. So to keep peace I opted for shorter wheelbase truck. Now I have debated that maybe I should of purchase a gasser which would of increased my CCC over 4,000 lbs but I do love my diesel.
Old 06-21-2015, 10:27 AM   #18
CWSWine's Avatar
I think a lot of misconception comes from the tow haul guides; I know I used them incorrectly when I purchased my first 5th wheel. Of coarse using dry weights also contribute to the problem also. I look at the 16,000lbs 5th wheel max tow capacity and thought I was good with a 38 foot RV – boy was I wrong. I had ton truck with diesel with 2475 payload off the yellow sticker. After installing the hitch, my wife, bed liner, few tools, and me and weighed the truck weight right at 8,000 lbs so now I have a CCC of 2,000 lbs with my 10,000 GVWR. Now I question my decision to put a diesel in ton truck, that 600 to 800 lbs extra took a lot away from CCC.
Previous RV: Next came a 28 foot trailer Cougar Ultra Light 28SGS (30 Foot) that had dry pin weight of 1410 lbs with dry weight of 7561 lbs with a CCC of 2439 lbs.
When I weight the truck I found that I was only 80 lbs of my MAX GVWR of 10,000 lbs (front axle4780/rear axle 5220) and the dealer telling me that his is ton towable. The 5th wheel weighed 8,700 lbs. loaded and ready to go camping so I had cargo weight left before max out my CCC on the trailer. NO matter what the dealer says the scales is the only way to verify you CCC of you truck and RV
So with a gross 5th wheel weight of 10,000 you could easily exceed the GVWR of truck with a diesel engine with a CCC of 2,400 lbs. Take away 400lbs of you TV CCC for hitch, people (2 people), fuel and etc leaving 2,000 lbs of CCC. Then 20% to 25% of the 10,000 RV is a pin weight of 2,000 to 2,500 lbs.
I heard all the arguments of why being over your GVWR is OK but I looking at the legal issue and trying say within the legal limits of my TV (GVWR as stated in the TV title) to avoid any kind of legal actions incase of an accident.
Old 06-21-2015, 10:59 AM   #19
CWSWine's Avatar
After weighing my 1 ton diesel truck and finding my yellow sticker on my truck door post 3744 in real life is only 3280 CCC. Using the standard 20% to 25% of 5th wheel weight as pin weight that would mean I would be limited to trailer of 13,000 lbs.
20% of 13,000 = 2,600 pin weight
25% of 13,000 = 3,250 pin weight.
No where near the 16,000 lbs 5th wheel towing limit.
Old 06-21-2015, 03:36 PM   #20
I have been reading the threads and I am a little confused.
I have a Prime Time Avenger 23FBS. It has a cargo carrying weight of 2,270 lbs. and a GVWR of 7,668 lbs. and each axel is rated at 3,500 lbs. each.
I tow with a Chevy 2500HD 6.0, 8 ft. bed & 4x4, with 4.10 axel ratio.
The GVWR of 9,200 lbs. with F. tire GAWR of 4200 lbs. and R. tire GAWR of 6,084 lbs.
Combined GVWR of 16,868 lbs.
I have not weighted the truck/trailer. However, when hooked up and on level ground, the trailer and truck show level.
Does it indicate, from fellow campers, I might be overloaded?
utahlucky is offline   Reply With Quote
weight
