Old 06-21-2015, 04:20 PM   #21
B and B's Avatar
Originally Posted by Oaklevel View Post
Sorry but no it does not give anything but what it started at........ During the shopping process I want to know gross not empty from the factory........... My 14,500 gross weight of the trailer means more to me than where it started at 9200. I want to know If my truck can pull it loaded at 14500 not if if it can pull it empty at 9200...... Dry weight is not that important.
I have to agree with Oaklevel. The gross weight and calculate the pin weight should be deciding factors. The DW and I were looking at a Columbus 325RL GVWR 13,800 Pin at full CCC estimate would be 2,200. We have enough payload for this trailer should we decide to upgrade. Some heavy things we won't have is Washer and Dryer. We would move the same gear over to the new trailer. Just looking for outside kitchen and more storage bay space for lawn chairs and rear rack for the generator, taking this from truck box.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-21-2015, 05:11 PM   #22
CWSWine's Avatar
Originally Posted by utahlucky View Post
Does it indicate, from fellow campers, I might be overloaded?
A while back I would say you go to go with that weight but after thinking I had lot of margin I would say put on the scales and see if the front and rear weights are over the GVWR. A lots of truck stops have scales and worth the 10.00 price tag for piece of mind.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 06-21-2015, 06:16 PM   #23
CWSWine's Avatar
I'm not sure where you get you pin numbers?
20% of 13,800 is pin weight is 2760 lbs
25% of 13,800 is pin weight is 3,450 lbs
20% of the dry weight of 10654 is 2343 lbs.
Anything less that 20% is to light for safe towing. You said in another thread that 2350?? on the Yellow tag on your truck which doesn't included hitch, passengers, fuel and etc. If you could take 2760 pin weight your truck weight would have to 7,240 lbs loaded and ready to go camping and I would guess that it's really close to 8,000 just like my diesel 3/4 truck was or 8,200 like my 1 ton. With the floor plan you are looking at I bet the pin weight would be lot closer to 22% or 23% of trailer weight just like mine is.
With my 315RST on my 3/4 ton truck I was really close to my rear axle max weight limit. My unload rear axle was at 3250 and with the trailer attached it was 5960 that was not loaded to go camping so a pin weight of 3,000 put it 50 lbs over rear axle weight.
I suggest you put you truck on scales loaded as you going camping and get the front axle weight + rear axle weight - 10,000 GVWR = That's really CCC of the truck and take all the guess work out it. If you dealer told you something different then he is wrong - the scales tell the truth and only way to verify your true CCC for any give configuration. Just to make sure check you truck title and make sure it does say 10,000 GVWR since that is the only legal document give max your truck can weigh.
If still don't think that correct stop by highway scales and ask the attendant that weights trucks for living - I did and got ear full.
Just trying to make sure when or if you scale the truck and RV you won't be like me and be 780 lbs over CCC.
My 1 ton has a yellow tag weight of 3744 but putting on the scales as it sits today with just me in the truck it 3,280 CCC. My 3/4 ton truck yellow tag was 2475 and with just me in the truck the it was right at 2,000 CCC
Old 06-21-2015, 06:36 PM   #24
CWSWine's Avatar
B and B
Found my weight slip -- The image attached is my weight slip for weighing my 3/4 ton truck with 315RST (33 foot 5th wheel). It was just my wife in the truck and the RV and just had the basic that we always keep in the 5th wheel. There was couple chairs, small gas grill, hoses in the basement small plastic carpet. Nothing in the bed room and no washer/dryer. truck bed was empty with 26 gallons of diesel and all water tanks empty. I added less than 1700 lbs from dry weight.
The trailer weight was 11,600 lbs
Truck without 5th wheel attached.
Truck front axle was 4700
Truck rear axle was 3200
As you can see on the weight slip I could exceed the Rear Axle Limits of 6200 lbs packed ready to go camping.
if you added Scale #1 and Scale #2 you will see if you add them together which is the truck GWVR is 10,740 and my max that listed on my truck title is 10,000 so I'm over by 740lbs
I now own 1 ton truck - problem solved with 11,500 GVWR and 7180 max rear axle weight.
Old 06-22-2015, 12:54 AM   #25
Tonkatoy77's Avatar
This question is to the OP. and something to think about. In Virginia you have to register the trailer (camper) by what it can haul. "Gross Weight", I do not know about other states. If there was an accident and no scale weight would not the courts go by what the trailer is registered for or its gross weight and if the truck is capable of 7000 lbs and the gross weight of the trailer was 9000 lbs. Is not the owner in deep poo poo...............
In Oregon we pay by length of the trailer.
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 06-22-2015, 03:25 PM   #26
Fulltime family RVer
I don't think that's an accurate statement. My camper's advertised dry pin weight is 16-17%. My normal loaded pin weight ran 17-19%.
My current pin weight loaded super heavy (i.e. moved out of my house, put everything we didn't take with us into storage, and are in the camper for a year+ long trip) has me currently at 16.4%.
It's a little bouncier- especially with the new pin box. I plan on readjusting weight a bit, but there's no chance I'll end up at or over 20%.
As for part of the OP, I've yet to read a first-person account of someone being ticketed (or having insurance woes) for being over the truck's (or even camper's) published weight ratings (in a non-commercial scenario). I've seen posts/comments about fines for the wrong license and registration for the weights (which use GVWR); but never anything first-hand for being over a truck's stickers.
And that's coming from someone who fully believes that I should be within my published ratings for truck + camper. I've weighed a variety of times and know where my weights fall.
Old 06-22-2015, 05:42 PM   #27
CWSWine's Avatar
My hitch talks about pin weight "Should Be" between 20% and 25% of trailer weight for safe operation. I have heard of less than 20% that have control problem they solved by adding water to tanks that were forward of the axles or loaded more forward to get the pin up. My Cougar 28SGS with rear fresh water tanks were full rode like bronco but empty it rode fine.
Floor plan also effects pin weights. A friends toy hauler with the back empty has pin win close to 4,000 lbs but with his three wheel Harley in the back has pin weight of just over 3,000 lbs. Gross weights go up but pin weight went down.
IF you do a Google search for "Lawyers over weight RV accidents" or "RV Accident Lawyers" you see pages of lawyers with ads that will take the case of a over weight RVs and some examples. I agree I have never heard of one either but how many people brag about being sued.
Old 06-22-2015, 05:51 PM   #28
Oaklevel's Avatar
It would be hard to prove your actual weight if parts of the TV or trailer are spread over the highway after an accident. Also would be hard to prove without a set of portable scales. The truth is there are not enough DOT portable scales to go around & there is more interest ($ & safety) getting 18 wheeler s that weigh 80K plus that are overweight off the roads.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 06-22-2015, 05:56 PM   #29
Oaklevel's Avatar
Wish I had a pic but if you were pulling a big camper with a Duelly Ford Ranger.........that might raise some eyes along the way.....& what would the capacity be........... There is a duelly Ford Ranger running around here
1966 Mustang GT
1986 Mustang SVO
Old 06-22-2015, 07:22 PM   #30
CWSWine's Avatar
I guess it would be the lawyer’s job to prove that RV max weight exceeds the capabilities of the TV. I guess it would be your responsibility to prove that the RV wasn’t loaded to the max. Who ever does the best job of convincing the Judge or Jury wins. Both lawyers make boatload of money. End of story.
weight
